Panasonic switching to standby mode on its own
When turning my 10 year old Panasonic CRT TV on (either from standby mode or at the switch) no picture (or sound) appears and it then quickly, within 5-10 seconds, switches itself into standby mode. This happens consistently, not sporadically - i.e. the set doesn't work. Is this a recognised symptom and if so can it be fixed, and how? I like my CRT TV and don't want to get ripped off being forced into buying LCD/Plasma.
    An expert who has answered 500 questions.
  • 556 Answers
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
Posted on Oct 08, 2007
My panasonic crt tv stuck on standby mode only
Hi. Replace the batteries in you remote control already ?
Normally, every TV can be switched on using the local "channel up/dwn " buttons. If this does not work, then there is a more serious problem at hand.
Apr 09, 2014 | Panasonic CT-27SC14 27" TV
I have a panosoinic tv model CT-2013SA and my son typed in a parental code and forgot it
There is a way to unlock Panasonic TVs. It will work on most of the Panasonic sets. Just try it.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, that is, switch on the set by its front panel power switch, and put it off by remote hanset, [standby position], then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
Feb 12, 2011 | Panasonic CT-20G6 20" TV
Unlock a panasonic tv
If you wants your Pansonic tv to be locked out there is ony way I knew.
Put your TV in standby mode and press the Power and Action buttons at the same time, and turn the main power switch or your TVs front panel to Off. The set should reset to Factory Defaults, and reset the V-Chip. Ok
Nov 17, 2010 | Panasonic CT2722H TV
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Panasonic: Switch from 'standby' to 'on' without remote?
No solution I'm afraid, but I also have this problem. Please help Dexstar and me: a turbulent two-year-old needs his Cbeebies!
Mar 26, 2010 | Panasonic TX-32PL10 32" TV
Hi, I have a Panasonic W32D2DP its about 5 years old. It worked fine until about 3 weeks ago. It started cutting off and going to standby. It worked fine after for a few more hours, then would do it...
It's going to be cheaper to buy a new TV. Once you get this problem solved, another one will pop up. The parts for a TV that's 5 years old are not going to be cheap. Most TV repair shops stop carrying parts after 4 years, & the manufacturer stops making them after 7-10 years. With a semi-major purchase like a TV, it's best to purchase an extended warranty. ipmart. com offers a cheap repair manual. You'll be suprised how expensive repair shops can be when it involves "out-of-warranty" work.
May 08, 2009 | Televison & Video
Tv lost picture and sound
Jan 12, 2009 | Bush 5693D 24" TV
Power issue
No picture on my Magnavox Big TV RJ8530 S/N 61998120
Aug 06, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Tv repair
Undoutably the SMPSU (Switched Mode Power Supply) is faulty.. This will be a shop job... ensure you get a firm "Quote" and explanation B4 allowing it to be fixed.
Jul 26, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
240 people viewed this question
Top Televison & Video Experts
