The menu says that I can Use the camera as a web cam, but I can't install it because I don'thave the driver and I don't know where I can get it, Windows xp can't install the web cam. Note I dont have any problem taking pictures or downloading them to the computer. Thank you
Built in web cam? Does the web cam work with the software e.g. - Microsoft life cam? If does not work at all could be out, get an external USB web cam. Could be a driver, could be the site or site settings.
Go to your computer's manufacturer's website or the web-cam manufacturer's website and search for the web-cam drivers for your computer model and operating system. Download the proper driver setup and run it, this will install the software for you to use the web-cam.
Now using the supplied disk install the camera software but please do not connect the camera YET, if the camera is already connected,
remove the camera and reboot,
so you installed the camera software now plug the usb camera in, it will now detect the install camera software and work.
step 1
Place the product installation CD in the CD drive of your computer. The installation wizard will start automatically. Follow the installation wizard prompts.
Step 2
Plug
the USB connector at the end of the LifeCam connection cable
into an available USB port on your computer when prompted.
Step 3
Place the LifeCam on a flat, level surface, or hang it from your computer's monitor. Continue following the wizard prompts until the installation wizard finishes.
Step 4
Click the "Start" button, then click "All Programs" on the Start menu.
Step 5
Click
the "Microsoft LifeCam" folder icon in the list of programs on the
Start menu, then click the "LifeCam" icon. That opens the LifeCam software and completes the installation process.
Here is the link to the website with the install discs of all manhattan cams I have also copied the instructions for your benefit.http://www.manhattan-support.com/driver-multimedia-cams.shtml 1. Make sure that the USB web camera is physically disconnected from your computer. 2. Insert Driver CD into cd-rom drive and allow autorun menu to appear. 3. Proceed with installation by explicitly following steps 1 through 3 of the autorun installation menu, restarting where necessary. 4. Connect the USB Web Camera to your PC. 5. Allow time for Camera drivers to be detected and installed. Ignore all Windows logo certification (or similar) messages and proceed with installation. Click on Windows Start Menu and execute the Pharoah Eye software application.note: make sure the camera is unplugged before installing.That should do it good luck,
1. Go to: http://www.a4tech.com/ennew/downloads.asp 2. Under the "Downloads" section, there are 2 fields. For the field "SELECT", choose "PK" from the drop-down menu. The second field will automatically display "130MG". Click the arrow next to this field & choose "7MA" from the drop-down menu. 3. Click the "GO" button. 4. In the next page, in the orange side-bar to the left of the page, click the "Driver for PC" button. This will start the download of the drivers for your web cam. 5. After the download finishes, & before installing the driver, make sure that you remove the old driver from Add/Remove Programs in the Control Panel, & reboot the computer. 6. Install the downloaded driver for your web cam.
There are 5 different models of Intex Webcams, since I don't know which one is your's, I'm sending the general driver support page of Intex, by following this (http://www.intextechnologies.com/webpages/download-driver.aspx) link you can select the appropriate model and download the driver. Hope this helps. (Select PC Webcam from the menu in the middle fist, then select your camera mode.)
1. Download this file. 2. Unplug your camera from computer. 3. Extract the file using WinRAR. 4. Open the extracted files and launch setup. 5. Follow the on-screen instructions. 6. After installation is finished, plug-in your camera to the USB. 7. The device should be detected automatically.
go to this link here you can download driver for 13 k web camera,100 k web camera,300 k web camera ,350 k old web cam,350 k new web cam,480 k web cam http://www.zippysltd.com/webcamera_drivers.htm
Here is the link to the website with the install discs of all manhattan cams I have also copied the instructions for your benefit. http://www.manhattan-support.com/driver-multimedia-cams.shtml
Insert
necessary.
application.
note: make sure the camera is unplugged before installing. That should do it good luck, Lee
