Question about Panasonic CT-32SL15 32" TV
Washed out colours and thin red lines across the screen
My six year old widescreen tv has suddenly started going strange. The colours seem very washed out and changing settings doesn't really make any change. There are also very thin reddish horizontal lines across the screen (clearest on black edges when not viewing in full wide screen mode) which are slightly higher on the right hand side. Both problems with colours and lines the same on all channels as well as when viewing DVD/VHS. Is it dying?
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Your problem is in red video circuit. please get it done with skilled tech.
Posted on Oct 05, 2007
SOURCE:
Why do the lights throughout the house pulsate when the washing machine starts agitating?
What make and model washing machine? How far is the breaker box from the washer?
Mar 24, 2017 | Washing Machines
Salt level doesn't work
I assume you are talking about a water softener. Mine runs off a timer - it is set to do its thing about 3 in the morning. If it is yours, check to make sure your timer is working (old motor and gear style or electronic, either could go bad) but if it is a rental unit, call them.
Dec 02, 2017 | Whirlpool Dishwashers
Accoustics solutions 37 inch tv colour fading and changing
Increase the color saturation to fight the fading and decrease brightness slightly. All of these settings are in the menu of the TV.
Jun 07, 2012 | Televison & Video
Colour on my alba tv looks wierd
Digital processor section and T'Con board should be suspected.
May 02, 2012 | Alba LDVD1538WDCH LCD TV
I have an old Sanyo 28" CRT widescreen TV. It works fine in PAL-50hz but when in PAL-60hz the colour constantly changes from colour to black & white and back again every few seconds.
I think the message is in your message - "old Sanyo CRT" (or old anything CRT, no discrimination towards Sanyo intended)
It's not LCD screen snobbery on my part either. I've a Panasonic 28" CRT I got new for £49 in a clearance only two years ago. OK it was a 2007 model but unused.
That will see me along nicely to avoid an LCD TV, I'll go for projection or LED screen when the Pana. dies.
However, this aint' getting us further along with yours.
Why do you need it to be in 60hz mode?
Is this something to do with viewing a USA NTSC system linked device?
Sep 24, 2011 | Televison & Video
We have only had our television a year, and the colour is starting to change on its own to a dark red tone, and the 4x6 screen has been burned into the screen, making vey annoying to watch anything...
U have an image screen burn in.This is not fixable.This have happen,because u left the same image or setting on same setting day in day out,tv on all the times.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Bush TV, model number RF6685VPL/A - Colours are wrong!
It seems that it is a degaussing problem. TV sets have a degaussing coil that when the TV is turned on , it automatically demagnetizes the screen. Never place any speakers or anything magnetic near or on top of your set. if you see swirls of color and like you say, wierd colors, it is that the screen is magnetized. Turn it on and off with the switch. Not the remote control. The degaussing coil only works by manually turn the switch on and off.
Nov 19, 2008 | Televison & Video
Sky not working properly on my samsung lcd tv
This is likely to be caused by the changing of the screen mode between ads and or programs, by your TV.
If so, changing the Sky output to 16:9 will fix it.
Press [Services]
Select option 4 - System Setup
Select option 1 - Picture Settings
Change "Location 1" TV setting to 16:9 (This will make the Sky box handle any changes and give you a permanent widescreen output to your TV. This is the recommended setting for widescreen TVs, but sadly, few Sky installers bother to do it.
You can also change "Location 2" if you have a second widescreen TV connected in another room.
Whilst in this menu change the Video Output to RGB from PAL (If not set already) RGB gives a much more stable picture (particularly on the menu system)
Go to Save new settings and press [Select]
Exit the menu system, and you problem should be solved.
Feb 20, 2008 | Televison & Video
Ratio
Does the sky box have a setting for output ratio? If so try adjusting it and see what the TV does.
Jun 08, 2007 | Polaroid FLM-2632 Television
Panasonic CT-32SL15 32" TV Logo
218 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
