Make sure that the correct cable is used vga to vga or dvi to dvi..... try some different cable.... try a monitor slf test you cannot access it by just removing the monitor cable..... if do get the test the monitor is bad
need to remove the rear panel of this xa3-17b monitor to replace data cable which is broken near the...
(More)
need to remove the rear panel of this xa3-17b monitor to replace data cable which is broken near the d-shell connector
I have a Dell Optiplex 360 computer with a service date of 9/7/09 that operates on the XP system. ...
(More)
I have a Dell Optiplex 360 computer with a service date of 9/7/09 that operates on the XP system. The monitor is Dell model E173FPc, manufactured 8/04. The monitor remains dark when the system is on even though the power is on as indicated by the power switch being green. All connections are tight. The computer system will work with a different monitor. Is it worth trying to fix the monitor?
