Question about Sony PlayStation 2 (PS2) Console
PS2 My Ps2 is the SCPH-30000 version of Japan. My games takes an hour of many resets to make it work. How will i make it one reset only to work? My PS2 is already modded
  • 709 Answers
Hi Kakashi654, Open the case and Disassemble the PS2 as far as you can. Clean all the dust from the console. Exam the lens and clean it thoroughly. Removing the dust can improve the reset problem. Check with www.playstationclinic.com is you need further assistance.
Posted on Oct 06, 2007
SOURCE:
Multi taps do'nt work with my PS2
Ok Turn On Your PS2 Make Sure You Don't have a disk inside. It should show you Browser, System Configuration, and if u press triangle it will take u to the Version menu go to console look at you console code ex. SCPH-77001. Then look at you muti tap to see if they have the same code if it does should work not the same code will not work.
Feb 16, 2009 | Sony PlayStation 2 (PS2) Console
Wrong multi-tap
I allowed my 11 year old to do it and now it works!
Dec 25, 2008 | Sony PlayStation 2 (PS2) Console
Which multitap do I buy?
There were two versions of the multi-tap made; one for the original fat PS2 and a smaller version made for the slim. The two versions are incompatible with the other PS2. If you have the original multi-tap connected to the slim, it should throw out the 'controller disconnected' message when you boot up. The slim version of the multi-tap should have a sticker on the bottom saying 'only works with models SCPH-70000, SCPH-75001, SCPH-75002'.
Other than the sports games, I don't recall any titles that allow more than two players anyway.
Nov 25, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
SCPH - 50004 Pal PS2 colour and reading problem
You need to buy those games which says PAL on it...Usually they have those PAL indications on the top right corner of the CASE of the DVD...of course you won't be able to play those NTSC games...it's just a compatibility issue, i think...cause your PS2 is a PAL model...
Jul 31, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Slim light turns on but no display
i've find a solution to this
a blown display chip is the culprit
as for my case the m,odel is SCPH 30000 (version 4 with gap)
I replaced the BA5815FM chip and now it works fine
i hope this will help
Jun 16, 2008 | Sony PlayStation 2 (PS2) Console
USB based joy stick
Well, assuming that your machine is an S.C.P.H.-39001/ 30000-50000 model, there should be two U.S.B. Ports on the front of your machine surrounded by a blue square, just below the memory cards and Controllers.
Jan 07, 2008 | Sony PlayStation 2 (PS2) Console
Ps2
Hi
I believe the SCPH-version 30000 through 50001 use the UBD ports for Playstation Specific Devices like the eyetoy.  The Slim PS2 has is more diversified and can read USB devices just like a computer.  To get details on your PS2, you can get detailed instructions at www.playstation.com.  sign up and go to Support for your older version PS2 and read up on connecting to the USB port.  You may find out how to actually do it. I have not tried my self.  I wish I could help more.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
PS2 DVD version
Hi SDK0013,
I am not sure which version PS2 you have but the only way to realy get there is to change the motherboard from one version to another.
I know that SCPH-50001 Motherboard will fit in a  SCPH-39000  case.
Oct 25, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
