Question about Logitech QuickCam Messenger Web Camera
My webcam wont stop freazing
I was useing my web cam n then it just froz so i thought ok ill just restart it but after i did i froz again n again n again n again so i checked my internet n swooped form one net to other same prob i got my brothers webcam witch is exstaly the same n got the same prob i re insealed the cam n still same problem i dont no wt else to do
  • 1 more comment
  • Anonymous Nov 29, 2007
    my web cam works fine on my computer. when I try to instant message with a friend, it sometimes works for a brief time and then freezes. most of the time we can't get a visual image. i disabled the firewall but it didn't make a difference. Any ideas?
  • Anonymous Feb 08, 2008
    I have the same problem , my webcam picture freezes after some time , i have tried to change setting , but still it is the same
  • Bigswede Apr 02, 2008
    My webcam, a Microsoft one I changed to after Logitec one kept freezing is just the same. Relogged Yahoo Mes. often to try to get cam stable, downloaded updates and gone back to older versions, checked and rechecked settings but all to no avail. Odd days it works but most times it continually freezes. Can't find a fix that works on the web either.
I was useing my web cam logitech version 8.30.0000 it just froz again and again
Posted on Jun 15, 2008
SOURCE:
When i go to update the driver for my web cam it tells me that it is already up to date, but when i go to use any program that uses the web cam it tells me there isn't one installed and it proceeds to...
Is this an external webcam or is it built-in? If it's external, follow these instructions:
Go to the webcam manufacturer's website and look for a driver download. Try installing it.
If that fails, next go to your driver settings, look for the webcam, and uninstall it. Restart your computer and install the new driver again. Restart again and try out the webcam.
If it's built-in, specify the exact model of your computer.
May 09, 2011 | Computers & Internet
My web cam not workeng
May be your web cam driver is corrupted. Follow these steps:- 1.Remove the webcam. 2.Restart the computer and connect the webcam. 3.Insert the web cam driver CD and install the driver. 4.Now your webcam will be connected.
Regards, polysandy
May 07, 2011 | Computers & Internet
My web cam is not attach my pc so what i do cam no vfo 330
Follow these steps :
•1
Get your webcam.
•2
Now Connect USB via Webcam.Then via PC.
•3
Now you will then have a setup popup so if you have a popup block un block it now and restart your computer.
•4
When computer it restarted you will do the setup. If the setup doesn't come up then check the connection and restart computer
•5
Then when setup is completed then make sure your web cam is up on your computer very stedy.Then do a test before you do a conversation. This is usually to see if you would need any extra lighting or not.
•6
Now enjoy webcam.I would recommend to keep your web cam connected so you wouldn't have to go though this again but if you cant then just reconnect and usually you would be ok.
Sep 25, 2010 | Creative Labs WebCam Live!
Web cam stop working
ok try to unplug cable of your webcam to your pc or laptop then plug it again!thank you
May 30, 2010 | Gear Head WC535I Webcam
Webcam doesnt work fro video calling and other internet activites
You are having an issue where there are two conflicting programs that are trying to control your Web Cam.
My thoughts is to go into the Control Panel and remove anything that has to do with your web cam. Restart and see if on your boot up if it finds new hardware.
Then I would try to reistall the software again.
Just a thought!
A/V Media Guy
Nov 22, 2009 | Dell Inspiron 1525 Laptop Jet Black
Pc restart when i try to use webcam on skype 4.1.0.166
hmmm! it may b ur RAM probz!!! chek cam settings! may tht USB port affecting ur RAM wich results in restarting!!
Nov 10, 2009 | Logitech QuickCam Pro 9000 Web Cam
My web cam built in dont work
You need to uninstall previos web cam driver/s from (control panel>add/remove>uninstall web cam drivers), restart the system and then install suyin driver
I hope this helps!
Aug 01, 2009 | Acer eMachines 520-2890 Notebook
How do I connect to the webcam?
hi..
Make sure you have or buy a webcam.Make sure you have an open USB port on your PC.
Step2Now Connect USB via Webcam.Then via PC. Step3Now you will then have a setup popup so if you have a popup block un block it now and restart your computer. Step4When computer it restarted you will do the setup. If the setup doesn't come up then check the connection and restart computer Step5Then when setup is completed then make sure your web cam is up on your computer very stedy.Then do a test before you do a conversation. This is usually to see if you would need any extra lighting or not. Step6Now enjoy webcam.I would recommend to keep your web cam connected so you wouldn't have to go though this again but if you cant then just reconnect and usually you would be ok thanks, please don't forget to rate our answers.
Feb 19, 2009 | Logitech Quickcam Chat Webcam
Webcam is not working
Is this the Acer Aspire One 8.9 -inch Netbook (1.6 GHz Intel Atom N270 Processor, 1 GB RAM, 160 GB Hard Drive, XP Home, 6 Cell Battery) Black
It's due to the software that starts with your PC. . .
Try
  1. Start Menu
  2. Run
  3. type MSCONFIG
  4. select Start-up Tab
  5. and disable the Web Cam Software
  6. Select Apply then Ok
  7. * Note it will ask to restart* Restart PC
  8. then open Messenger again and try web cam
Dec 23, 2008 | Computers & Internet
Not working
unplug your web cam then restart your computer after then when computer loaded all programs and stable plug your web cam when pc recognizing it and ask for driver then put cd and follow the wizard instruction guide.
Nov 01, 2008 | Logitech QuickCam Pro 5000 Webcam
Logitech QuickCam Messenger Web Camera Logo
394 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
