Question about HP PSC 2210 All-In-One InkJet Printer
Problems with cartridges
Dear Sir, Lady We filled black and colour cartridges with ink,but the printer doesn't working. We can see "remove and check cartridges" on the LCD. Please let us know, what should we do that the printer accept the filled cartridges again. Your faithfully: S?ndor Csende
    President:
  • 2,961 Answers
It may be that the printer does not see the cartridges because they have been removed and then the contacts may need cleaning, but see this link for other soilutions http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042821&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
Posted on Oct 06, 2007
SOURCE:
Dell V305w Printer Alignment problem. Remove tape from cartridges or check troubleshooting. Press > to continue. Ink cartridges reset, tape removed, trays aligned. HELP!
In my case this happened with black cartridge out of ink, colour cartridge low; replaced black: had permanent alignment problem, though test print looked OK; wouldn't print black. Replaced colour cartridge, then it all worked OK, straightaway!
Aug 24, 2010 | Office Equipment & Supplies
Canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Ink cartridge problems
exchanged the black cartridge (57): the printer told me there was a problem with it, that I should remove it and re-insert it. I did, the ink button still blicks. After several efforts the printer started to work again, printed one document and then told me there was a problem with the colour cartridge. I removed it, re-inserted it several times. Finally a test page was printed - everything was okay.
Then the printer refused to print anything - the yellow LED lamp blicks continuously. Have turned the printer on and off, have also shut down the computer and re-started.
The only thing that will work now is the black cartridge, if I remove the colour one.
May 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
The printer is working again - I exchanged the ink cartridges yet again, and finally the printer accepted them. Still don't know why the problem developed.
Apr 28, 2008 | HP DeskJet 5150 InkJet Printer
I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
Filling is easy - but messy. I use No 40 cartridges for my pixma ip2200.
For the black cartridge, carefully remove the label. Drill a 2-3mm dia. hole in the depression in the top. With a syringe fill, using about 10ml of black ink. Plug the hole with a suitable bung and away you go!
You will however lose the ink level indication as it is not a genuine cartridge - but that is unreliable anyway.
Don't refill more than a couple of times as the foam inside the case eventually perishes and all the ink runs out.
Whilst the cartridge is out of the printer give the jets a wipe with a wet tissue. This is usually quite effective in removing dried on ink.
You can do the same with 41 colour cartridges but it is a bit more tricky locating the correct place to drill.
Good luck
Apr 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP PSC 2210 All-In-One InkJet Printer Logo
22 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
