Loewe TV with pin cushion distortion
After approx 20 minutes once TV is switched on, the screen distorts with a pin cushion effect - the sides of the picture curve inwards. If the set is left on, the apex of the curves become staggered and the picture that remains, reflects this distortion across the screen. Can you please advise the probable causes and possible cures. I'm an end user with an electronics background presently unable to locate a repair manual.
  • 2 more comments
  • loewelover Oct 06, 2007
    Hi Troy,
    Aconda 9381ZW - ART 59401H62
  • loewelover Oct 09, 2007
    Hi Troy,
    Have now obtained a manual for this model, but would still appreciate guidance. Plaese see attached.
  • loewelover Oct 10, 2007
    Cheers Troy, will give feedback as soon as I can.
    Many Thanks
  • loewelover Oct 28, 2007
    Troy, the set developed another fault - psu due excessive use with pin cushion problem. In the end for swiftness had to call a service engineer. If I'd acted more quickly your solution would have rectified the problem. Caps kept as souveniers.
    Kind Regards
    Genius:
  • 1,153 Answers
Yes if you could give me a model #, it is probably a diode shorted in pincushion area, or a capacitor.
Posted on Oct 05, 2007
  • Lashawn Robinson Oct 08, 2007
    Yea this is a unique model, you have a leaky capacitor in your pincushion circuit. If I had a picture of it maybe I could point it out.
  • Lashawn Robinson Oct 09, 2007
    From what I see in the picture, it looks like you have the same blue caps that the RCA has in it that goes bad. If you look under the red anode lead from your flyback. This is the part that goes to the picture tube. there is a blue looking box type capacitor. These are the caps that goes bad in RCA models. Also you have the gray type right next to it. Look closely at these caps sometimes you can tell which is bad. If the sides are not smoothe, but rounded out and looks like it's about to explode then it maybe bad. Also look for something that may say pin cushion area, I cant tell from the picture. But check and if you find something change it.
I have Prima TK 2951 CRT TV AND i have vertical problem. Which capacitor i should change to fix picture from sides have corregations from down to up
You're talking about the pin cushion distortion; I presume. If this is the case, there is a separate circuit to adjust pin cushion distortion. Contact any service technician to rectify this problem. This is a skilled work. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 06, 2016 | Prima Televison & Video
Almost 4inches wavy form in the center of the screen...
Pin cushion distortion. Contact any service technician. Your TV need a through check up. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 03, 2015 | Televison & Video
Picture is distorted, enlarged, and bowed at the edges.
Pin-cushion distortion. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 14, 2015 | Loewe Aconda ACO9383 38" TV
Picture is too large to show on screen
Check its "Pin-cushion" section circuit for the fault. An IC is used there to control the pin cushion distortion. If this IC has got faulty, this type of fault can occur. This is actually a skilled work. If you are not ahndy, seek any technicians' support.
Jun 18, 2012 | Sony KV-36XBR400 36" TV
SONY KV SW 212 M80 Screen sowing pin cushion distortion. Screen is squeezed on the side and the side is curved inward.
Hello
Its pin cushion distortion circut had some trouble with it. There is an Ic and one transistor wich controls the pincushion effect. In most cased the trasistor that fitted on a heat sink, will have loose soldering at its terminals. this transistor will heat up during working, and repeated heating an cooling will make solder terminal loose contacted and it is normal fault. locate this transistor, very near to the LOT, resolder its solder terminals by applying a little more solder. It is best to resolder most of the surrounding solder terminals of high watt resistors, without making any solder bridge in between the solder points. If these does not helps you, replace both the IC [an eight solder terminal one, small IC] and the pin out transsistor described earlier at the same time. this will solve your TVs problem. OK.
May 22, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Vertical Distortion fix for Toshiba 32 inch TV
You have bad capacitors and possibly a vertical IC that is going bad. And check for bad grounds in and around the IC and caps!
Dec 10, 2009 | Televison & Video
Loewe Xelos TV 7 years old - screen image has colla_psed at the sides so appears distorted viz )_( shape. Is it a write off?
look for an square transformer near the LOT,underneath the transofrmer there is a resistor that can be defect.Measure al capacitors in East West circuit for bad capacitance.
Jul 27, 2009 | Televison & Video
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Televison & Video Logo
1,371 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
