Question about Linksys Wireless-G WRT54G Router
Status is connected, but can't access webpages/messenger/p2p
I just moved into a new apt with wireless router. i can connect to the router no problem, but i can't surf the web or do anything, its like i'm not really connected to the internet. can anyone help me?
  • cacwi Oct 05, 2007
    i realized that on the status page of the router config, it changes from disconnect status to connected. this happens at random and it doesn't always reconnect automatically.
    any suggestions?
    President:
  • 2,961 Answers
This problem can happen either when your ISP is having a server problem and changes their WAN IP address to alter your speed, or the speed that they are syncing your line at is too fast for it to handle and therefore will keep dropping the ADSL signal until the line itself balances the speed out over a 24 hour period, the same can apply with cable.
Posted on Oct 05, 2007
SOURCE:
CAN'T GET A UNSECURED SIGNAL, AND WHEN I DO, THE WEBPAGE WON'T LOAD. RADIO SHACK TOLD ME TO PUT IT ON A USB CABLE TO EXTEND ITS RANGE. BUT NO MATTER HOW STRONG OF SIGNAL I CONNECT TO WEBPAGES STILL WON'T...
Hi, The easiest way would would be to install a DSL line in the APT and connect direct. Have you got the correct WEP key to the wireless networks? Do you ever have a warning that you are connected with limited connectivity or acquiring address takes ages? If so, you may be attempting to connect to a network with the wrong key. In addition, it may even show you are connected, yet you cannot access pages. Have you ever succeeded in connecting properly?
Please provide answers and I will try to help some more. Regards, Icom1
Apr 05, 2011 | Computers & Internet
I own a d-link router, and i have a problem....the status light is always flashing, never stable...is this normal? the connection seems to be ok, but i have some problems with messenger(instant...
Yes, the status light indicates activity so it is normal for it to flash.
First, the obvious, it is possible that some of the videos are damaged...moving on...
Router troubleshooting:
It is a good idea to disconnect the power to your router for at least 30 seconds every few weeks. You should also do this to any hubs/switches between your computers and the router. Logon to router and try to set the MTU to 1492. Make sure only have one router between you and the Internet. Many ISP's refer to bridges and routers as modems so it is hard to tell. If your router connects to "modem" to access the Internet try connecting your computer directly to the "modem". If that works better then you have multiple routers "Natting". (Google: double nat) Finally, try a different router.
Computer troubleshooting:
Scan your computer for problems using Malwarebytes.org. Install all available "messenger" updates and fixes. If you are referring to Windows Messenger it has been replaced with Windows Live Messenger which is a free download. (Google: Windows Live Messenger)
I recommend that you start with the easiest recommendation to follow and, if necessary, continue to the next easiest. Don't try to do everything at once.
If this helps, please vote for my solution.
Jan 28, 2011 | D-Link (DI-784) Wireless Router
I set up network in my office with SMC wireless router. All the PC are connected. They can log in into yahoo messenger, skype but they can not access webpage with brouser
If there is any firewall running locally on your network, turn it off.
Then try again. You will be able to browse. If u are able to access skype, yahoo messenger, then u should also able to access websites too
Oct 05, 2010 | SMC Computers & Internet
Describe your cannot connect my cga5722 wireless
well you need to reset your router wireless config, your isp dont do this, you need to config yourself, but i give some help. try these manual steps:
4.1 Log on the webpages
Open your Internet Browser
Enter http://192.168.2.1 in the address field
Click on GO
• The following webpage will be displayed
Note
The only default language is English.
To access the required webpage, click on the corresponding tab on
the left side of the page.
4.2
Webpages’ menu structure
The table below describes the menu tree of the webpages.
4.3 ADSL/Internet Settings webpages
4.3.1 ADSL status
Click on "ADSL Status" which is located on the left side of the screen.
SET UP WIZARD Getting started
Wireless settings
ADSL settings
Confirm
The ADSL Wireless Base Station also operates as a wireless access
point, allowing wireless computers to communicate with each other. To
configure this function, you need to enable the wireless function, define
the radio channel, the domain identifier, and the security options.
Check Enable and click "SAVE SETTINGS".
You must specify a common radio channel and SSID (Service Set ID) to
be used by the ADSL Wireless Base Station and all of its wireless clients.
Make sure you configure all of its clients to the same values.
Access Control allows users to define the outgoing traffic permitted or
not-permitted through the WAN interface. The default is to permit all
outgoing traffic.
If the signal strength of a single wireless base station is not sufficient due
to a large coverage area or attenuation due to walls, with WDS the
range of a wireless base station can be extended.
All base stations in a Wireless Distribution System must be configured
with the same radio channel, and encryption type (WEP/WPA) if that is
used.
i send a link for these steps more datailed on:
http://download.p4c.philips.com/files/c/cga5722_05/cga5722_05_dfu_eng.pdf
Jan 16, 2010 | Computers & Internet
How does one go about setting up his own wifi system in my apt
Get an access point or wireless router.
Connect the AP or wireless router to your network.
Configure the AP/router to use encryption
Get a client adapter for your client device, and configure it to connect to your network.
That's it in a nutshell.
If you have more specific questions, I can give you more specific answers.
Nov 21, 2009 | Actiontec Computers & Internet
Router lights are blinking - no connectivity
is your router in range. When I moved I had to get an atena to get a good signal. walls were thicker.
Jun 09, 2009 | D-Link DIR-625 (790069292637) Wireless...
Not able to connect to internet
1. try to check the status of the connection:
make sure it is connected and the status does not say either of the ff:
a. local only
b. limited or no connectivity
c. limited access only
2. try to change the network name [ssid] and the network key [wep or wpa passphrase]
you can change this by accessing the ipaddress of the router or its user interface
3.try to reconnect to the new network name
and make sure the status says connected.
this is not a browser issue . it is with the connection set up.
Aug 05, 2008 | Microsoft Broadband Networking MN-500...
I cant get virgin netgear router to connect to my medion laptop, i get to the last part of the installation process when it says attempting to connect to newtork and it comes up move your connections...
Have you accessed and setup your wireless part of the modem?
To access the router settings menu, you will first need to log into the Wireless router following the steps below:
Open Internet Explorer
In the address bar type the following address:
192.168.0.1
You will be prompted to enter a Username and Password to access the interface, please use the following default details:
Username: This can be found on the bottom of the router
Password: This can be found on the bottom of the router
From the list on the left hand side, click on ‘Router Status’.
Within the Router Status section there are two areas you will be able to access:
Show Statistics
Connection Status
The Router Status page gives you a detailed status overview of the connection configured on the Wireless router.
Click ‘Connection Status’ to see more information on the broadband connection.
If you have already configured your broadband, you are able to establish/terminate the connection by clicking Connect/Disconnect.
You can also click ‘Show Statistics’ to show you current connection speed and more information on your Broadband connection.
Clicking on Basic Settings enables you to check all the Internet settings of your Broadband connection. Including the Login name (username) and password, IP address and type of connection.
Clicking on ‘Test’ will perform a standard check of your Internet connection and settings.
ADSL SETTINGS
The ‘ADSL Settings’ section provides you with some more information about your Internet connection. These are:
Multiplexing Method
VPI
VCI
WIRELESS SETTINGS
This section gives you full information regarding the Wireless connection. From here, you can change security settings, the SSID (Name) of the router and the access control list. Options list from:
Name(SSID) virgin broadband (default)
Region Europe(default)
Channel 11(default)
Mode g&b(default)
Enable Wireless Access point
Allow broadcast name
Security options (None, WEP and WPA)
- hope this helps
Jul 03, 2008 | Computers & Internet
Cannot access router webpage
Make sure your firewall and anti-virus are switched of then try and connect to the webpage
Jun 13, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
53 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
