Heating element Zanussi washing machine
Hi, how do I gain access to the heater element in my Zanussi FL828/A so that I can replace it? Thanks.
  • 1 more comment
  • braulioluis Feb 08, 2008
    how can i replace the heater element
  • braulioluis May 11, 2010
    can you please send me a diagram and instruction to remove the element on zanussi washing machine my address is
    what does the heat element look like..because when i turn the drum it makes a noise, it is not bearings
  • 209 Answers
Remove the back, the element is at the bottom of the drum tis maybe a split cabinet, where the lid comes off the it splits down the middle like cracking an egg, loads of screws, hard to describe, also 2 at bottom at the side in the middle, behind 2 plastic lugs, when removed the back half of the cabinet comes away, not an easy job until you have seen it done if you really are stuck try and send me an e mail address and i will send you a drawing, then you will see its easy, i am an engineer of 20 years and done loads, its easy job to do once you know how to split the cabinet
Posted on Oct 07, 2007
How do I finish removing the rear half-cabinet of a Zanussi FL828 washing machine?
Carboran Tub
1. Remove the ring fastening the door gasket and disengage said gasket from the front panel.
2. Disconnect the tubes from the tub (soap dispenser-to-tub, vapour discharge, tub-to-filter housing, etc...)
3. Disconnect all component wiring connectors fastened to tub (motor, heating element, thermostats) and adjustable thermostat bulb, if any.
4. Remove the motor
5. Unscrew the four fastening screws and remove the back counter weights (only on machines provided with such counter weights).
6. Remove the two pins fastening schock absorbers to the tub.
7. Lay the machine flat front-face downwards (placing in-between some means of protections, such as polystyrene, cardboard and the like, so as not to scratch the cabinet).
8. Disengage the tub's suspension springs from the cross-bar with the aid of a piece of string.
9. Remove the tub from the washing machine.
10. Remove the driven pulley.
11. Remove the motor (if you doesn't before)
12. Remove the 17 screws which fasten together the two shells.
13. Slide out the drum.
Jun 17, 2015 | Zanussi Washing Machines
How to fix a heater zwg 7120p
You will have to purchase the heating element which for your model might look something like the one shown on this site.
Washing Machine Heating Element with Sensor
The instructions to replace this should come with it.
If not then try to download instructions from here which is usually similar for most European front loaders like yours.
How to replace washing machine element front mounted in Bosch washer
Sep 02, 2014 | Zanussi Washing Machines
How do I hgain access in order to replace the heater element on my Zanussi dw 905 dishwasher?
You can get details from the manufacturer .
Jun 23, 2014 | Dishwashers
How do i replace heating element in a zanussi washing machine
It depends on the model of washer.
If it has no removeable rear panel, then you have to remove the complete rear half of the cabinet to access the heater, not an easy job.
If it is an early model, then it will have a removeable rear cover, and the heater can be changed from the rear of the washer.
Feb 12, 2011 | Zanussi Washing Machines
My dishwasher does not do a hot wash. Why is this? If I need to replace the heating element, how do i gain access to heating element on my Bosch classixx dishwasher?
Hi, a common problem with these machines is the solder coming away from the heater relay. A simple repair if your lucky. Run a continuity test on the element with a multimeter before replacing it, as it is a massive job to change it. I just changed mine yesterday, the machine had to be totally stripped down. Although its not an impossible task, it does take some time. A kindly man on this site sent me a manual for Bosch dishwashers, which helped me enormously on stripping the machine down. I don't know if it is any good for your machine, but if you give me your email I will send it on to you. Mike :)
Nov 29, 2010 | Bosch SHU9950 Dishwasher
Zanussi jetsystem turbodry 1600 wjs1665 w is not heating the water
More than likely the heater element has failed.
This is located at the rear of the washer drum.
It means removing the rear half of the cabinet to access it.
Mar 29, 2010 | Zanussi ZWF1430W Front Load Washer
Zanussi FJD1666W heater removal.
There is no easy way to access the heater without stripping it down.
Remove top cover.
Remove 2 scews at rear bottom of cabinet.
Remove 2 plastic covers at front bottom sides of cabinet, and remove 2 screws located in holes, you will need a nut socket to remove them.
Remove inlet hoses, and undo screw at top where the hoses connect to, prize up the plastic retainer that holds the valves in place.
Remove screws at top of cabinet that hold the 2 halves together.
Then lift rear half of cabinet clear of the front.
At the bottom rear you will see the heater element located.
Undo center nut and remove element..
Fit back all parts in reverse order.
Not an easy job. Good luck.
Plz rate my solution.
Jan 14, 2009 | Zanussi FJS1225W Front Load Washer
Need instruction manual for FL828 Zanussi
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
At this site you may find where to go to get it!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
You will be fine now!
Bless you,ngfam1
Aug 28, 2008 | Zanussi FJS1225W Front Load Washer
Heating element
hi yes they are different the fc1200w element is 1600 watts (£31 part 150867200-1)the jetsystem zwf1658 1900 watts its always better to use the correct part.
May 03, 2008 | Zanussi FC1200W Front Load Washer
It could be a malfunction heating element, thermostat or both. In most of the cases it's the heating element. Check with a multi-meter for 115/220V on the heater element tags. In case you get this voltage there, you should replace the heating element. In case you can't read the 115/220V on the heater tags: - Check thermostat's for continuity (you should read a low resistance). In case you can't get any measurement. You should replace the thermostat. Good luck!
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
1,268 people viewed this question
Top Washing Machines Experts
