I have just put in a new biostar motherboard with a new intel duo processor and now cant even get the computer to turn on there are no fans and i have checked all the power connections
I CORRUPTED MY MOTHER BOARD CD I WANT INSTALL SOUND DRIVES
Hi check the cables from the case to the mother board. They should be marked and the book that came with the board will tell you where to connect them. The std markings are HDD [red led] PWR S [powerswitch] RSW [reset switch] PWR LED [case power light] To test if there is no fault in the board or power pack. first visualy check the board to see if you have a red led light on when the power is turned on, if not the problem is in the power pack or the wall outlet. second if the light is on, the bridge the pins marked pwr switch on the board with a screw driver and this should start the computer, if not you have a faulty board. Regards mistyman
The p23g V1.0 motherboard doesn't support the core duo processor. Do not try to install it or you may damage either the board or the processor.
The p23g V3.0 support also the core duo processor
Follow this link and you can see for each motherboard the different processor used.
http://www.pcchips.com.tw/PCCWeb/Products/ProdMBModel.aspx?CategoryID=1&TypeID=9&MenuID=92&LanID=2
My suggestion is that you use the p29g
I have managed to get power now to processor and fans and hard drive i think but the monitor won't come out of stand-by when every thing is switched on!!! any ideas?
Ifinished putting together my computer, m motherboard is a inteldesktop DG43NB to start up it said to push power and delete buttoms at same time, should hear some beeps, but i don't hear anything, all the power is on and DVD, Harddrive is working, where have i gone wrong??? HELP PLEASE,
NANCY
