Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Conon Super G3 Copy Fax Scan
The fax is hooked up to my telephone line, but it only lets my home phone ring once. How can i set the amount of times my home phone rings befor the fax takes over?
I`m trying to scan a multi paged document into my dell inspiron 1521 laptop , however when I scan the doc it will only scan into images not into microsoft word where I want to make changes before e-mailing the doc.-----I lost the original in microsoft when the old comp.crashed. Any suggestions would be appreciated.
Posted on Feb 23, 2008
I have a Brothers Laser Fax Super G3 and I need someone to come and hook it up for me. Whenever the phone rings, the fax goes off and I have it indicated for phone/fax mode. Can you send a service p
Hello
Make sure your fax line just connect to one device (just fax device)
sometimes other device cause this problem.(and you must know most (old ) telephone lines can handle up to 3 devices (if you connect more than 3 devices, you may have some noise on the line or disconnected other devices issue or even your line fuse may damaged due to low amperage.
what you can do?:
1- disconnect another device and check
2-use another line
3-use ADSL Splitter to decrease your noise on the line
4-check your telephone cable for probably damaged
5-go to certified repair center for checking
regards
Ali Karbasian
Dec 08, 2014 | Brother Office Equipment & Supplies
There is a fax failure when receiving a fax. The activity report said REMOTE FAX ERROR. What have I not set correctly? We have never set up the fax before so have no previous history. We are using a...
If you have specifically requested a "double" ring pattern for your fax from Telus, then you have the right setting, otherwise, select the Any ring pattern to avoid fax transmission failure.
For more troubleshooting steps, please refer to this Lexmark article about Main Contributing Factors to a Fax Receive Failure on Inkjet All-In-Ones.
Sep 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hi: I need to adjust the number of rings before the fax answers? what do I do ?
Hello main229,
It may be useful to check the help menu in the sowftware that was installed with the SUPER G3 FAX BOARD-T1. It usually shows how to set the amount of rings befoe the fax answers.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 02, 2010 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
FAX LINE NOT RINGING TO TELEPHONE
This is what is called a ring trip.
unplug your fax machine and plug in a normal phone. call the fax line. let it ring a few times. if the phone rings, but not the fax machine, check the cord of the fax machine and replace it. if the fax machine still does it, there is a short circuit somewhere in the machine. it is most likely in or around the jack that connects it to the phone cord, check for corrosion or bent contact pins.
if it rings only once or not at all, then check the phone jack for corrosion. trace it all the way back to where your phone line connects to your house. if it is still not ringing, call your telco to get them to check thier equipment.
Jan 15, 2009 | HP LaserJet 3055 All-In-One Printer
Need to change my ring tone in Fax Canon laser class 2050 G3
Press dataregestration,use the arrow to go to rx settings,select rx settings with the set button,go to incoming ring,select and switch it to on,and then cange the ring count to the amount of rings you desire.
Jan 06, 2009 | Office Equipment & Supplies
Don't know how to set for receiving phone calls and faxes on my all in one
Wat I always do, is set it for fax only,and the incomming must be on and set ringcount to 8 times.You will never loose a fax and 8 rings give you time to get to the phone.
Oct 29, 2008 | Office Equipment & Supplies
Fax query
This sounds like you have smart ring on your home line. Smart ring lets you have 2 seperate telephone numbers, One for fax and another for phone, but 2 distinctive rings all one one line. Check your manual to see if you have this feature and to set it up.
Jul 10, 2007 | HP 920 Plain Paper Fax
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
816 people viewed this question
old marine
old marine
