Question about ASUS P4S800D-X Motherboard
OVERCLOCKING When I press the power button on the front of the case, the pc seems to start with a bit of disk drive whirring, no beeps though, and the monitor does not turn on. I then have to turn off the power off at the wall, turn it back on, press the power button on the front of the case, and then the PC starts and shows the following message: Overclocking Failed! Please enter Setup to re-configure your system. Press F1 to Run SETUP Press F2 to load default values and continue As I haven't changed any settings in the BIOS, if I press F1, the BIOS shows exactly how it was before. The PC then starts fine and I have no trouble whist in Windows. If I press F2, the PC then starts fine and I have no trouble whist in Windows. If I shut the PC down completely, and then press the power button on the front of the case immediately afterwards, the PC starts up fine. If however, I wait few minutes to turn the pc back on, the same issue arises, ie the pc doesnt start up and the monitor doesnt turn on.
  • Anonymous Mar 20, 2008
    I have the same problem, it look like who ever own this motherboard have this problem. Is there any fix to this? I have 2 gb and tried to take out 1 gb same thing happen, tried to take out 512mb still same problem. Sometime when I press the power button the first time the computer turn on but not my monitor and when I turn it off and turn it back on it works. When it work it also pop up a screen say overclocking failed. Hope there a fix to this.
    Brigadier General:
  • 6,966 Answers
Hi, On other motherboard models of Asus, similar problem was corrected by: 1. Updating the BIOS; 2. Actually overclocking the FSB to slightly higher than default (say 170 or 175 from 166, 140 to 150 from 133); 3. Slightly increasing the default processor voltage supply by increments of 0.05; 4. Replacing the 3.0 volts Lithium battery; 5. Replacing the memory to next higher speed; Never had problems like this with MSI, ECS or Intel boards. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
I had exactly the same problem.Upgrading the BIOS did nothing. I had a 1 gig and a 512 memory modules. By removing either one, I solved the problem. Either would work by itself, but not together. There must have been a compatability problem with them working together.I don't know what the speed of either one was. Good luck.
Posted on Dec 23, 2007
SOURCE:
Pc not booting, no fans spinning, nothing lights up. HALP
REWIRE THE ELECTRIC WIIRES.SHOULD THAT NOT HELP TRY WITH A OTHER PSU.
Dec 06, 2013 | Computers & Internet
My PC when plugged in does not turn on but only powers the fan
Is there beeps coming from inside the tower case? Does the Hard Drive make a spinning sound after about 15 to 20 seconds? It could be a mother board issue, it could be a graphics card issue.
Jan 17, 2013 | Packard Bell Computers & Internet
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
1 - 3 to 4 second beep about 4 seconds apart, no boot
motherboard is doing a check and failing something another component either CPU, Monitor or memory usualy) (google search bios beeps for your make/model) to determine what.
if you cant find it, just ensure the above 3 are correctly seated by taking them out and putting them back in again.
Apr 21, 2011 | Computers & Internet
My ps3 has stopped showin the icons but its loading up the front screen is there but no icons ?
Your software needs re-installing, follow this procedure :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep once more and switch off back into standby mode (red light on)
Step 3. Press and hold the power button again. It will beep when you press it, then beep again 5 seconds later, then there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
Step 4. The PS3 will start up asking you to connect a controller via USB and press the PS button. Do this and then move onto the next step.
Step 5. A menu will load up with 6 options. Choose option 3 first "Restore File System" and go through this process. If this does not work do the above but choose option 4, then as a last resort option 5. A warning though, option 5 will erase all your data on the hard drive.
Hope this helps and thank you for using FixYa
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
Hard disk drive has been corrupted it says system will be restored then it goes then it says hard disk drive has been corrupted.
hold power up front until you hear 3 beeps then remove fingr. hold power up front again till you hear 2 beeps then a double beep. connect remote via usb press ps button and pick option 3 it will not erase anything.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Will not start up
If it's not beeping during the first start up then it's not POSTing.  Beep means everything connected to it seems to be functional ie PnP
Try pulling out your memory and reseating it.   Try pulling out your battery for 5 minutes then plug in ac(without batt) and see if it will boot.  Try pulling your hard drive and reseat.  (access by covers on bottom...dont be scared. Touch something that's grounded just before you remove) If all this and still no full POST(with beep/s) then sounds like a new mobo or processor.
James Mac
Sep 09, 2008 | HP Pavilion dv9000z Notebook
Seagate freeagent 500g usb 2.0 beeps sound
I am so happy to say that i HAD the exact same problem.
Its an issue with the drive disk itself. Long story short because i dropped the drive the the disk was no longer able to spin fast enough to start the drive (the beeping sound actually being the disk trying to start spinning.
After spending literally the last 4-5 hours looking for a solution I found a unusual method that basically either works, or it doesn't there's no it kind of works. what you need to do is unplug the drive, then plug it back in and start Vigorously spinning it whilst keeping the drive horizontal (similar to what you would do when your unscrewing a light bulb).
You have to try and do so simultaneously with the beep and it should "kick start" the drive (AND OBVIOUSLY DON'T LET THE WIRE DROP OUT AS YOUR SPINNING IT AS YOUR COMPUTER WONT RECOGNISE IT IF ITS NOT PLUGGED IN).
I Know this method sounds far fetched but put it this way, 15mins ago I was working out how im gonna get hundreds of pounds to restore this drive, Now, i've just finished copying my informations onto a laptop from the drive so i can take this piece of plastic **** back to the shop :D.......
Never again Seagate and Thank God for letting me find a solution.
Feb 11, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
ASUS P4S800D-X Motherboard Logo
232 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
