Question about Pioneer AVH-P6600DVD Car DVD Player
In dash dvd bypass
The brake wire on my indash dvd has an inline fuse so does this mean I have to find a power source instead of a ground in order to bypass it. I would greatly appreciate your help.
  • 2 more comments
  • Sp0rt4320 Nov 20, 2007
    I installed my dual 8181 and i grounded the video wire... all was good until i put in gear and it said my E-Brake was still on.....Any suggestions
  • saint636 Feb 11, 2008
    parking brake bypass
  • Anonymous Apr 05, 2008
    how do i bypass
  • icenbigirl Oct 05, 2008
    how do i bypass the e-brake
You have to get a switch and run the green to ur ground.when u turn car on flick switch and ur problem is solved.switch can be bought at radio shack for 3-5 bucks.any on off switch.
Posted on Oct 22, 2008
  • 1,586 Answers
Sport4320, you have to have a switch on the wire, so you can break the ground. The alternate method, which I found online, is this:
This will work with out haveing to do anything to the pink wire just tape it and leave it alone. But the next time you unhook ur battery cable you will have to put the code in again.
Put in DVD
right when the blue screen comes up
hit STOP twice
punch in 1,2,6, and 4
hit DOWN 1 time not 2
hit PLAY/ENTER
**at this point the display became visible and i could now see the menu which made it much easier.
hit DOWN one more time to change macrovision
hit PLAY/ENTER
hit SYS SETUP twice to save and exit menu
Posted on Oct 08, 2008
BYPASS THE KENWOOD DDX8017
Im guessing since this is an in dash dvd player your trying to bypass the emergency brake so it will work with the vehicle in drive. If this is the case all you have to do is take the wire that goes to the emergency brake and ground it somewhere.
Mar 04, 2013 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
How do i bypass the parking brake switch in order for my video to play
Take the wire that they tell you to hook to your parking brake and hook it to ground instead.
Feb 27, 2009 | Pioneer Car Audio & Video
Jensen vm 9312 parking brake bypass
Here's what you need to know: DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On the Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In mine, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in the manner of the e-brake cycle I mentioned earlier.
Sep 17, 2008 | Car Audio & Video
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 25, 2008 | Dual XDVD8181 Car Video Player
Aug 23, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
I installed my in dash my self but i dont know how to bypass the e brake screen?
Aug 18, 2008 | Car Audio & Video
Parking brake (pink wire)
Aug 13, 2008 | Car Audio & Video
There isn't any code that I know of. Most DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On mine, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
Jun 25, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
Bypass parking brake wire
Boss Audio is the easiest in-dash DVD on the market to bypass; all you do is ground the ebrake wire. I recently installed 12 Boss Audio in-dash BV-7300's and did this to all of the decks problem solved. By the way I did this because they were in the back of limousines where the driver couldn't ever even see one of them while he was driving. I don't think there will be a problem, try it.
May 20, 2008 | Boss DVD-7500 Car DVD Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
Pioneer AVH-P6600DVD Car DVD Player Logo
323 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
