Question about Hotpoint 24 in. DWF32P Free-standing Dishwasher
Hotpoint DF31 Dishwasher
Hi, Hotpoint DF31 leaks in fresh water when idle,after every wash I shut water inlet off which seems to cure the problem, could you please help,also best contact for parts, many thanks
  • Anonymous Mar 21, 2014
    dishwasher stops part way through cycle
  • 447 Answers
You need a new inlet valve. Axcessed through bottom panels below door there are screws in the four corners of the upper one. Inlet valve is where the water line meets a plastic body with wires going to it. www3.sears.com for parts.
Posted on Oct 05, 2007
Dishwasher is on and connected to water, but no water coming in.
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 27, 2011 | Hotpoint 24 in. FDW60 Free-standing...
What causes the cold water in a washer machine to come out real slow?
Hi
This may be either due to blocked inlet hose or low water pressure. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the inlet valve seems to be fine then make sure that the filter screen is clear & clean. If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back with model# if you need more information.
Daniel
Dec 19, 2010 | Washing Machines
Dishwasher is not filling up with water
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter hen you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Oct 25, 2010 | Hotpoint Dishwashers
Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 11, 2009 | Bosch Dishwashers
When the water cycle is running there is a white plug by the water inlet that is leaking. When the dishwasher is not in the water cycle it does not leak. When the dishwasher is stopped in the middle of the...
crack in water inlet valve or a pin hole in the hose going from the valve to side of tub spraying water where you see it. You have a holein someting. You need to trace it back to its sourse. When you say "water is running"im guessing thats when its filling with water not just washing.
Oct 30, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Water over flow on a1267302ew DWU9200ABX Maytag dishwasher
There are three common causes for water leaking from a dishwasher door or float.
1. A problem with the wash system. Check the wash arms for cracks and or splits in the underside that can cause water to jet down and out the front of the unit. Check all water supply tubing in the unit as this can cause the same problem.
2. It is not uncommon for a water inlet valve to fail open and allow too much water into the tank causing a leak.
3. Over sudsing can cause a leak. Make sure fresh dishwasher detergent is used in moderation.
Go here for Maytag Dishwasher Parts: http://www.repairclinic.com/Maytag-Dishwasher-Parts
www.RepairClinic.com
Feb 10, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Hotpoint dishwasher model BFI62
water leaking into base of machine. tip dishwasher back and drain out water. then check all seals intact, i.e. around arms, around salt holder etc
Dec 23, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Step one in the diagnosis would be to check to see if you have a good water supply. Remove the lower kick panels and loosen the water supply line to the machine at the inlet valve (usually located in the left front looking at it from the front. If you have water coming to that point, remove the wiring connections at the inlet valve and see if there is 120volts present when the unit is supposed to be filling. If there is, replace the inlet valve. If there is no voltage, it turns into a far trickier diagnosis.
Oct 19, 2008 | Kenmore 15129 Built-in Dishwasher
Hotpoint WM64 doesnt seem to be taking in enough water
Close your faucet valve & unscrew your hoses to check screens on hoses & machine. Clean out well. Refit, check for leaks. Water shd be in good pressure. If this is not the problem change your inlet valve, it is easily done. Suggestion: use powders for front loaders.
May 08, 2008 | Hotpoint WMA32 Front Load Washer
Water Leak
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
of the dishwasher, the following instructions probably apply to you.
But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the
entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly.
You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the
rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten
or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues
to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the
dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the
leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Aug 14, 2007 | Hotpoint 24 in. DF55 Free-standing...
Hotpoint 24 in. DWF32P Free-standing Dishwasher Logo
128 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
