Question about Samsung SGH-D900 Cellular Phone
U 600 bluetooth
I,ve had my u600 for 6 months and all was well.i tried to bluetooth some tunes to another phone but it just kept coming up failed,people can send me stuff,my phone picks up theres and goes to send then after 10 seconds it comes up failed it serches and picks up other phones but don,t let me send. please help
  • gypsycristi Nov 26, 2008
    same problem with u900. tried the hard reset and didnt work... bummer
    Brigadier General:
  • 7,752 Answers
DO A HARD RESET
*2767*3855#
Posted on Jul 01, 2008
SOURCE:
My bluetooth is paired to my Pantech P6020 but it won't automatically connect.
Unfortunately there are different versions of bluetooth. Pending on the age of the handset.
You could try a bluetooth adaptor
Dec 28, 2017 | Cell Phones
All the lights on my dash kept coming on and going off for about 4 months. Then all of a sudden the car just died on me at a stop light. Now my battery is dead; but i've tried to crank it many tim
it could be the alternator . measure the output voltage across the battery with the engine running and car in neutral with hand brake on. It should at least 13.4 volts.
If it does then I would get the battery checked at a car battery place.
A car battery place could also check your alternator.
If you are stranded at the lights suggest calling a mobile car battery replacement person or a road assist company if you are a member of one.
They can jumper a temporary mobile battery across your battery to get car out of traffic stream !
Feb 23, 2018 | 2006 Chrysler PT Cruiser
It will not turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 18, 2012 | RIM BlackBerry Curve 8520 Smartphone
Im trying to use PDAnet with bluetooth I have the bluetooth card installed on my laptop tuning vista, and it has an error that says that I need to install the bluetooth software for the phone, and I've...
Make sure you have bluetooth on on both, and that you are connected via bluetooth to your computer.
Turn on pda net on your DI and enable bluetooth dun.
Now go to your bluetooth settings on your computer and double click on your device, a new service should pop up allowing you to enable dun/modem and select that.
right click on your di bluetooth connection on your computer and create a dial up modem.
select the generic bluetooth modem, not the pdanet modem.
Type 123 in the phone number and leave the username and password blank and click connect.
Now you can right click on your DI bluetooth icon on your computer and select connect to the modem connection you just created.
After using my DI as a modem over bluetooth there are a few things to consider.
1. yeah it works great.
2. Its a battery **** fest.
Constant 3g with constant bluetooth = constant battery draw.
I would still recommend using your pdanet via the usb cable, seeing as this will keep the battery level charged, as well as same speed!
Aug 29, 2011 | Motorola Mobility Droid X
My Soyo Free Styler 600 bluetooth headset did not come with instructions, how do you get it to work with the blackberry curve?
on the soyo freestyle 600 you have to power on the device (hold power for about 5 sec) then hold either the volume up or volume down button, I forget, for another 5 sec it should go into pairing mode (Blue-->Red flashing) youre blackberry should b in search mode for bluetooth devices at this point. Then youre blackberry will recognize the device and ask for a passkey (0000 default) registration will be complete at this point once the blackberry recognizes the headset..
Jun 13, 2009 | Soyo FreeStyler 600 Wireless Headset
Forgot pairing passcode for BK 600 bluetooth headset
the passcode should be 0000 I've looked into two manuals for it I think I may have to look in to a 3rd? let me know if that didn't work and I'll triple check it.
Thanks,
Ekse
Feb 20, 2009 | Cell Phones
KG800 - nice phone, but it kept disconnecting the bluetooth connection in my car (built into the radio system). The shop replaced the phone with another KG800, but problem remains. Could it be a fault with...
It could be try connecting another phone with the car's bluetooth and see if that works if it does you know where the problem is coming from.
Jun 21, 2008 | LG Cell Phones
Big problem!
Not all Bluetooth are compatible. I've had trouble sending from a Nokia to a Panasonic. "**** is nature's way of saying: high!"
Apr 09, 2008 | Sony Ericsson Z610i Cellular Phone
Samsung SGH-D900 Cellular Phone Logo
54 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
