Question about Philips DVP642 DVD Player
Problem with starting
My dvp642 dvd player right know is starting when i switch on the supply it starts blinking the power on LED and doen't start but when i remove the power supply of main bord ie prosessor the power supply LED remains stable but again if i put the power to processor again it start blinking
Just replaced the old 1000uF cap.  with a new 1000uF 35v, so far the dvd is working great.  I couldnt find a 16 volt cap. but the 35 volt works fine.  This is the fix.
Posted on Oct 16, 2007
Read on a forum that changing out c316 1000uF will fix the problem, mine will not turn on now, seems to have gotten worse over time. I will change the capacitor from 1000uF 10v to 1000uF 16v.  Look at your capacitor, mine looks like its ready to blow.  Most other capacitors on the board are rated at 16 volts.  I will be changing out the cap. to see if it works.
SOURCE:
Power light blinking unable to turn on
And get no display?
Probably the power supply, or some other relatively catastrophic problem happened.
If it's still under warranty call Philips tech support first, for possible replacement.
Else you're probably looking at buying a DVD player, unless you want and are willing to open it up and fix it your self (time consuming).
Jul 20, 2010 | Philips DVP642 DVD Player
My Philips dvd player model DVP642/37 is not working. The stand by/ on button flashes the red light on and off slowly and non of the other buttons respond on the machine or the remote for the dvd player...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Apr 21, 2017 | Philips DVP642 DVD Player
My dvd blink red light on batton standby/on.I can't turn on!?Any idea,please!
In most cases you need to reservice the power board, or change the damaged capacitor. This capacitor is loacated on poer supply board. Also resolder the components heated area. Hope this works.
Jun 23, 2010 | Philips DVP642 DVD Player
Stuck dvd and no power
I fixed this problem in my DVP642 by replacing a capacitor on the main power board where the power chord hooks in. Take the top cover off (after unplugging player). You'll be able to locate the bad capacitor on the circuit board located on the very right. Look for location marked c316 on the circuit board. A bad capacitor will be bulged up on top. The capacitor you're looking for will be a black barrel shape with an aluminum top, this aluminum top will be bulged up or leaking on the circuit board. Replace this capacitor by desoldering the two leads into the board and replacing with an identical part you can pick up at Radio Shack for a couple dollars. My repair for this identical problem was a success. The blinking light is the tip off for this particular problem on these Phillips models.
Oct 08, 2009 | Philips DVP642 DVD Player
Blinking red light
Check
http://www.fixya.com/support/t2763934-philips_dvp642_dvd_player_blinking_red
Problem is solved there!
Aug 16, 2009 | Philips DVP642 DVD Player
Power light is blinking on my philips dvp642 Dvd how can I fix this?
sadly it sounds like a bad power supply. does the unit even play? It can be fixed. Try this link it is from Philips.
http://tech.groups.yahoo.com/group/philips_dvp642/message/1720
good luck :D
Aug 09, 2009 | Philips DVP642 DVD Player
Panasonic dvp642 Blinking light
Pull out the power supply, it needs at least one bulging cap replaced - while you are there change a few in the area - I've done a few of these repairs - no probs.
Jul 17, 2009 | Philips DVDR630VR DVD Recorder/VCR
No Power
IF YOU ARE FAMILIAR WITH A SOLDERING IRON THIS IS A VERY SIMPLE FIX, IT IS SIMPLY A MATTER OF FAILED CAPACITORS ON THE POWER SUPPLY COMPONENT BOARD.
USUALLY A PAIR OF THEM OR MAYBE 3, VERY SIMILAR TO THE SAME ISSUE WITH PHILIPS DVP-642 MODEL.
REMOVE THE TOP <WHICH YOU HAVE TO DO TO REMOVE THE DVD> AND YOU WILL SEE THE BULGED OUT CAPACITORS, THEY WILL PROBABLY HAVE GUNK ON TOP OF THEM.
Jan 26, 2009 | Philips DVP642 DVD Player
Philips DVD Player Seems Dead
It looks like this problem has been discussed here: "Standby light blinking."
Mar 24, 2008 | Philips DVP642 DVD Player
Power button just blinks,no buttons work
To get your DVD out of the non working player, you have to look on the bottom of the case below the tray. There you will find a little slot, about 2 cm long x 2 mm wide. Through that slot you will see a white plastic piece, sometimes its on the middle of the slot and sometimes its full to the left of it (the front of the player facing you). Use something that can be inserted in the slot (I used a little knife) and move the white plastic piece all the way to the left, that will loose the tray. Then you will be able to open the tray using your fingers, nails or anithing that won't scratch the finishing of the case.
Aug 23, 2007 | Philips DVP642 DVD Player
Philips DVP642 DVD Player Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
