Panasonic Plasma TV - Viera TH-42PX60B
Hi I have a Panasonic Viera TH-42PX60B TV which is 18 months old (out of warranty) and not working and I was hoping you could help me, When you try and bring it out of standby nothing happens except that the power light flashes 10 times then pauses and flashes 10 more times. Can you tell me what this diagnostic code means and perhaps what would be required to fix it? Thanks in advance Glenn
  • loppet Dec 29, 2007
    Tv tripped all sockets in living room, new fuse replaced in tv plug, all other appliences ok now but tv still not working. Stnadby swith flashing 10 times over
  • bonhomme Feb 18, 2008
    I have the exact same probleme. I just moved house and when i switched the tv on in my new flat it started behaving the same way. I asked an engineer to come and check what was wrong, he told me it must be a pannel, the tv switches on because there is no power prbleme, then it does a self-diag to check anyt other pbm, if it detects one, it goes into this "stand-by sate" with the flashing led : me it's 11 times. i don't know if it is an error code as the bios beeps on a computer but the tech guy couldn't tell me. I have to take it to a repair center, which would cost me several hundreds. If someone can help to find out what part is faulty.
    thanks
SOURCE: Home cinema/Viera link problem
Turn everything off and disconnect from mains.
Wait a few minutes.
Disconnect HDMI cable.
Turn on TV and DVD.
Connect cable.
If this does not work use a cable of different spec.
I had the same problem and now mine works .
Good luck.
T.P.
Posted on Oct 31, 2007
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
  • 8457 Answers
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Posted on Nov 23, 2009
Testimonial: "cool thanks alot"
tvhelp-Dave
  • 178 Answers
SOURCE: error codes. no picture or sound after turning
When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
Posted on May 16, 2010
I,M USING 42INC PANASONIC VIERA PLASMA TV WITH THE MODEL NO TH-42PX60B AND THE SERIAL NO IS 6562190 AND THERE IS A HORRIZONTAL LINE ON MY SCREEN SO I CAN SEE THE PICTURES WELL THE SCREEN IS DIVIVED INTO...
Hi, my name is John. Welcome to FixYa. Its your horizontal output transistor, and a few capacitors. I will post the tools and steps needed here......John
Nov 30, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Tv wont turn on, red led flashes 10 times
If this is NOT projection, then the power supply is burnt out. If it is projection, then either high voltage transformer, flyback, or power supply is at fault
Nov 08, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
TV switched itself off and will not come on.
try unpluging it and leaving it over night then try again and if not the tv might be stuffed
Sep 02, 2009 | Televison & Video
Sens 23" LCD tv cd combo
Good news - it's under warranty. Take a look at:
http://www2.panasonic.com/consumer-electronics/support/Televisions/VIERA-Plasma-HDTVs/Warranty-CCP/model.TH-50PZ80U.W#ts
Aug 07, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera 46" plasma~no sound, no picture
I would use the warranty at Bestbuy at that point. Opening up the TV would most likely void the warranty.
Jun 28, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Panasonic Viera link and Foxtel IQ
It is very likely that cross talk does corrupt the link but for Panasonic to "blame" anyone else is not very professional. Anyway, if it worked for 6 months perhaps disconnecting the Foxtel IQ and reestablishing the Viera link with the Panasonic devices then reconnecting the Foxtel IQ for another 6 months of happy viewing. This is not a permanent solution but the alternative doesn't seem to be an option.
Feb 26, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
No sound in TH-42PX60B
I don't know the exact situation without properly checking out the set. But, from my perspective I strongly suspect that you are trying to recieve station that are on a slightly different broadcast system, where the sound carrier is not compatible to your set.
We always tell our clients that when changing countries, it is best to sell your video equipment before leaving, and then re-buy new when at the new location. I've seen this type of thing many times.
Jerry G.
Jan 11, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Green interference on Panasonic TH-PX75U
Since the set is only 8 months old, it should still be under warranty. This may only be an internal connection problem, but opening up the unit will void the warranty. I would suggest that you call for warranty service. This is a problem with the set and has nothing to do with external devices or interference.
Keep us posted.
Dan
Jul 10, 2008 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH-42PX60B
have you already service the main unit, or you an initial check on the parts of the TV..
kindly post back the TV model/maker..
Thank you
May 18, 2008 | Panasonic TH37PX60 37 in. Plasma...
Televison & Video Logo
460 people viewed this question
Top Televison & Video Experts
