Question about EliteGroup P4VMM2 Motherboard
What is maximum supported IDE harddisk in ECS P4VMM2 mother board and I'm using 1.7 GHz processor and 512 RAM and windows server 2000 OS.
  • 2,961 Answers
Normally 137gb but updating the bios will allow a larger size to be recognised.
Posted on Oct 05, 2007
I have a 512 DDR2 (533 FSB) RAM in one of my slot in Intel D102GGC2 Mother board,can i put a 2 GB DDR2 ram in another slot.If yes then What FSB will match and what is the maximum capacity of ram per slot?
This motherboard will support maximum 2 GB of total system memory. so configuration is should be 1GB + 1GB or one 2GB in one slot. If you attempt to install 2GB + 512MB, this is unsupported. but you can try if might the system can read it or not. there is no serious problem for installing memory exceed than maximum system memory...
Memory supported is DDR2 533 Mhz and DDR2 400 MHz...(sometimes on the market DDR2 533 will described as module name PC2-4200 and DDR2 400 as PC2 3200)
Aug 10, 2011 | Intel D102GGC2 Motherboard
Hi can Sony Vaio PCV-RS602 mother board support a sata hhd
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
  • Type: Personal computer
  • Form Factor: Tower
  • Processor: 1 x Intel Pentium 4 3.2 GHz
  • Processor Main Features: Hyper-Threading Technology
  • Cache Memory: 1 MB L2 Cache
  • Cache Per Processor: 1 MB
  • RAM: 512 MB (installed) / 2 GB (max) - DDR SDRAM
  • Storage Controller: Serial ATA ( Serial ATA-150 ) ; IDE ( ATA-100 )
  • Floppy Drive: 3.5" 1.44 MB floppy
  • Hard Drive: 1 x 160 GB - standard - ATA-100
  • Optical Storage: DVD±RW
  • Optical Storage (2nd): DVD-ROM
  • Card Reader: Yes
  • Monitor: None.
  • Graphics Controller: AGP 8x - ATI Radeon 9600 XT
  • Video Memory: 128 MB
  • TV Tuner Type: Analogue TV
  • Audio Output: Sound card - 5.1 channel surround
  • Communications: Fax / modem - 56 Kbps
  • Networking: Network adapter - Ethernet, Fast Ethernet
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 06, 2011 | Sony VAIO RS602 (PCV-RS602) PC Desktop
    I am using Intel845 motherboard and intel 2.4 p4 processor and 1gb ram. Can i install windows vista or windows 7 or microsoft server 2008 , is they supported to my Configuration. Any updates need to meet...
    For Windows Vista to work : It requires minimum 2.0 ghz processor, 1 gb RAM and 60-80GB hard disk.
    For Windows 7 : It requires minimum processor 3.0 ghz, 1 gb RAM and 60-80 GB hard disk.
    Otherwise, your operating system or hardware problem will occur.
    Dec 29, 2010 | Microsoft Computers & Internet
    I have 512 mb ram, 2.66 2.66 ghz processor, intel chipset Fifa 08 works well on my pc Is it possible to play Fifa 09 for me?
    You shouldn't have any trouble.
    Minimum System Requirements for Fifa 09.
    CPU with 2.4 GHz (single-core)
    512 Megabytes of RAM (1 GB required for Windows Vista?)
    DirectX? 9.0c Compatible 3D accelerated
    128 MB video card or equivalent
    (must support Shader Model 2.0 or above)
    DirectX? 9.0c Compatible Sound Card
    512Kbps or greater
    broadband connection for online gameplay
    MS compatible mouse
    Mar 03, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
    What are the processor compatible with this mother board pvmm2? my current proc is celeron 1.8ghz. im planning to replace it with p4 proc? i tried p4 2.26 ghz but it wont work?? pls give me adviced for...
    Note that a faster front side bus(FSB) or system bus as listed on the above page will make a slower cpu faster the a cpu with higher Ghz and slower FSB.
    Also RAM is your best upgrade, fast and easy.
    Jan 10, 2010 | EliteGroup P4VMM2 Motherboard
    My system is hanged after few minutes
    Well the issue could either be with the bas sectors on hard disk or faulty RAM or a burned capacitor on the motherboard.
    The very first thing I would suggest you is to reinstall windows operating system.If the issue persists then run the system with another RAM and observe the performance.
    if the issue persists then it could be with the motherboard or the power supply. Manually check the capacitors on the board for any leaking or faulty capcitors.
    Let me know if you need any further assistance
    Aug 08, 2009 | Intel Motherboard
    To know good hard disk
    I think that Western Digital Hard discs are reliable with affordable cost. But if you put a little money more Seagate offers better stability.
    DDR1 or SDRAM?
    Either or else I think Transcend is your solution and it is better to go to 2GB of Ram to see better improvements.
    Mar 09, 2008 | Tablets & eReaders
    Compatilblity with 845G mother board
    try update the system bios because there were motherboards that had compatibility problems, this board is not a new one so it should work with your processor
    Feb 07, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
    Windows xp
    kgprakash, Did you check your BIOS's Main Page to see if the board is reqognizing the drive correctly? If so did you change from Master setting to Cable Select or vice versa? Some drives don't like to play nice. Have you access to a differnt drive, just to see if XP finds it. If you have SATA or Raid capabilities on the board read the manual this messed me up for awhile (the Asus I use has 6 internal Sata ports and one IDE legacy connector). If you only have IDE, are you in the connector marked or known as IDE0? Just some thoughts.... Pcdok
    Oct 21, 2007 | ASUS P5S800-VM Motherboard
    EliteGroup P4VMM2 Motherboard Logo
    69 people viewed this question
    Top EliteGroup Computers & Internet Experts
    Alun Cox
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
