Question about Samsung Digimax S630 Digital Camera
Samsung camera power-on problem and beeping
Camera turns on, shows image in lens for about 3 seconds, beeps three times, then shuts off. Lens is stuck in out position and camera is warm to the touch near the flash.
  • 14 more comments
  • Anonymous Mar 27, 2008
    the lense is stuck and it makes the beeping sound.
  • 3tailedfox Apr 26, 2008
    the lense won't shut and it turns on for about 3 seconds then turns off but nothing is on the display screen
  • Anonymous May 07, 2008
    Same prob here... Except mine was very severe. I actually had to stick my finger nail around the silver piece around the lens and pry it off. Then it worked perfectly. Thanks to this website!!!!
  • cccookie May 11, 2008
    i turn my camera on. No image appears. Then it beeps three times and the lens stays out and the camera wont turn off.
  • Doc_owner1 May 24, 2008
    My camrea turns on beeps three times but the lens stays closed!!
  • Prcleburne Jun 11, 2008
    My problem is very similar, but my lens is stuck in the in position and I cant get it to come out, The green light does flash one time and it beeps three times.
  • momalley930 Jun 21, 2008
    I have the same problem but my lens is not stuck and there is not way for me to grab at it. I didn't drop it so just becareful this doesn't happen again. Mine is still now working
  • Anonymous Aug 11, 2008
    I have the same problem and eventually in desparation I took the cover off to see if I could spot anything. I turned the lens inside and things appeared to click into place. Problem is that I think I have now disconnected the power switch at the top. I think that camera is now a bin job unless anyone can give advice about what I might have done wrong.
  • Anonymous Aug 13, 2008
    camera beeps four times and then shuts off
  • Anonymous Aug 31, 2008
    I turn on my Sampsung camera, and it continues to stay on for about 3 seconds,after it beeps 3 times, and turns of automatically. i have tried to move the lenses, but it is really hard, to move them and i cant get it to stay on the right place. Does anyone provide insturctions to move them on the right place please?
  • steids Sep 26, 2008
    Camera beeps three times
  • desilew Sep 26, 2008
    Whenever I put in my batteries, the power only last for about 2-3 minutes. It beeps me and says "low battery", but the indicator on the camera reads the battery life as full. I brought new batteries and a charger, so I know it's not the batteries.
  • sammer18 Oct 02, 2008
    i have a samsung digimax S600 and I turn it on, the screen stays on for about a couple seconds and then it starts beeping and then turns off. The lens is still stuck out as well.
    what do i do?
  • fdwengen Dec 06, 2008
    Our camera Does the same with brand new batteries beebs then turns off we tried all types of batteries Model 630
  • loafy15 Dec 07, 2008
    i try turning on my camera, stays on for a split second, makes a slight popping sound and shuts off. tried new batteries, but to no avail..
    somebody help me please!
  • cooperstevey
    cooperstevey Jan 02, 2013
    i have a samsung digimax which i thought was lost but it turned up in an old bag it has never been drooped but when i try to turn it on it beeps 3 times and goes off,i have checked the lense and there is nothing wrong with it,can someone please help .
Same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
Posted on Mar 31, 2008
  • John Ross
    John Ross Nov 05, 2012
    Worked perfectly for me as well, was on the verge of turfing the camera, thanks
Omg thankyou o much i had my camera for my 13 and it was brand new, solution:>Camera got dropped..had the same problem here, looked after reading this and the smallest part of the telescoping lense was just a little tilted. Gently moved it out and popped it back, works fine now.
Posted on Aug 14, 2009
  • x3cna Nov 13, 2010
    What do you mean my "Gently moved it back, and popped it back." Can you explain it to me?
    I got the new Samsung PL200. and it's like 2 days old, I dropped it by accident. :/ I that my telescoping lens is tilted a bit. I need the help. I love this camera. :)
    Thanks for your help.
My camera was stuck with lens open, beeped three times with no other action wwhen I pressed power. I fiddled with the lens as mentioned above and it now works. My fiddle I mean, I tried to align them (even though they already looked aligned). Not sure if I dare to take it on my 2 week holiday,
Posted on Jul 07, 2012
Same problem - lens had got stuck & screen wasn't working. So recharged batteries, put them back in & had the start up beep & sometimes the 3 beeps. Nothing obviously out of alignment with lens but gave it a wiggle & it retracted next time I tried turning it on, but still wouldn't go. Plugged in my phone adapter & it worked. Turns out must have been the lens, plus the rechargeable batteries had got too old & lost charge. Hope this helps someone.
Posted on May 13, 2010
I HAVE A SAMSUNG L301 CAMERA WITH LENS STUCK OUT I,VE REPLACED BATTERY AND CAMERA TURNS ON BUT LENS STILL STUCK AND I CAN,T GET ANYTHING TO WORK
Posted on Feb 04, 2011
Sometimes pulling a little harder is needed don't be afraid to do it, and you may have to pop it once or twice..
Posted on Jun 10, 2008
Had this problem on a Samsung D85. When I took the back cover off I noticed that the metal frame of the LCD was at a slightly different voltage to the negative battery connection. Less than 0.1volts so I was doubtful that it was anything important. Anyway I soldered a wire between the minus battery connection and the nearest bit of the LCD frame. Problem was solved.
Posted on May 16, 2012
I have a totally different problem with my samsung,there is a permanent blue light & will not work,any ideas peeps?
Posted on Nov 12, 2011
Thanks For the Advice Guys that happened to me tonite! My samsung kept beeping; then i looked at lens and it was tilted.. I popped it back...Thank Yall :)
Posted on Sep 12, 2010
Camera got dropped..had the same problem here, looked after reading this and the smallest part of the telescoping lense was just a little tilted. Gently moved it out and popped it back, works fine now. Another thank you for the tip!
Posted on Dec 24, 2007
The above advise about gently pulling and twisting the lens worked perfectly.  Thank you so much!
Posted on Oct 31, 2007
I just had the same problem and figured out what it was with my camera.  One of my kids had got it and turned it on and then dropped it.  The lens looked as if it was fine, but when I took a closer look I realized that it had been stuck on one side.  I grasped the lens on each side and gently pulled while twisting and it popped back into place.  I then turned it back on and off again and the problem was solved.
Posted on Oct 15, 2007
    Problem Solver:
Solution worked great!! I was just about to give up & buy a new camera. I LOOKED at my lens that was extended & it WAS tilted just a little. I gently pulled it & it popped into place. THANKS!! I really like this camera because it's simple to use-so hated to have to get a new one!!
Posted on Apr 14, 2010
Same problem here. I observed the smaller piece of the telescoping lens looking tilted. Grabbed it and pulled it gently away from the camera body. It popped out a little, seated itself level and retracted itself. Good as new! Thanks for the tip.
Posted on Nov 03, 2007
  • 53 Answers
You need a new charger or a new mechanism filter whcich allows you to enduce and privde more frequent stabilty for the lense and its froiter
Posted on Apr 26, 2008
3 Suggested Answers
hittin1
SOURCE: samsung s630 camera
okay.... Try this if lens is stuck out... look at the side profile of the lens... you should notice the it is not even.. the lens is probably stuck at a slight angle.. GENTLY force the lens to where it looks even... should fix the problem.... worked for me.
Posted on Feb 25, 2008
  • 3 Answers
Finallly sent it in for repair - two times! First time, it took several weeks before I got it back. When it arrived it still would not work, so it had to be sent in again. Then they tell me I broke the camera myself so if they are to send it back (unrepaired) I would have to pay them $50. At this time, paying shipping costs back and forth I figured it wouldnt be cost effective. All together it cost me a total of $200 for 15 pictures taken with the first battery set, which after it would do nothing but beep three times. Some people mention the cause being that they dropped it, but I never did, it was like that straight out of the box.
Posted on Jun 24, 2008
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Camera Stuck with lens out. Beeps
I dropped the camera on the table a couple of times, twisted the front of it. Suddenly the lens retracted into the camera, the beeping quit, and now I can take pictures again. The Samsung website is horrible.
Jun 03, 2009 | Samsung Digimax S630 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Why is the camera beeping?
I had t he three beep problem and also the lens was open. I tried batteries - then i noticed the lens was slightly bent - i tried straightening and it snapped and went into place. then i tried turning it on and it was fine and when i turned it off the lens closed.
Maybe your lens is bent.
Jun 28, 2008 | Samsung Digimax S730 Digital Camera
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
The lens doesnt close and when i turn the camera on it bips three times and the screan shuts off. the lens wont close.
The batteries need to be changed. The digital batteries sold at the stores die out too fast. I had this same problem. In result, I purchased rechargeable battieries.
Nov 19, 2006 | Samsung Digimax S500 Digital Camera
Samsung Digimax S630 Digital Camera Logo
6,712 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
