Question about Ovens
Baker's pride pizza oven needs repairs
I work with 4 Baker's Pride Pizza Ovens from hell. These things seem possessed and nobody seems able to fix them. Actually 1 out of the 4 is working adequately enough but the others all suck. They all stay lit but just don't get hot enough to cook anything worth a crap. One of these three used to be my best oven ; it would get dangerously hot and you had to be very careful when using it because it would burn things quite easily if you weren't constantly tending to it- but I loved it... then one day it just wouldn't stay lit; then repair man came, now it stays lit but doesn't get 1/10th as hot as it once did and it sucks... I'm up to my ass in weak and ineffective and I have had it -Can anyone offer me any suggestions or advice? many thanks from Karla in Gold Canyon, AZ.
0 characters
1 Points
I have a bakers pride pizza oven and the bottom oven Including the pilot light) continue to go out for no apperant reason. I have changed the thermocouple 3 times and the pilot light once. Sometimes it...
Several things to check. First be sure the pilot light flame is directly striking the thermocouple. It is a pencil sized rod that is next to the pilot light. Sometimes people reduce the size of the pilot flame to save gas. You may need to increase the pilot flame. Follow the small gas line from the pilot flame back to the gas valve. There is a screw where the small pilot gas line goes into the valve. Remove the screw and then deep in the hole is a tiny screw that can only be reached by a tiny flat blade screw driver. Turn the screw counter clockwise to increase the pilot flame. The thermocouple needs to be red hot to work properly. The second item to check is to see if there are any breezes that occasionally blow through the kitchen. Sometimes the hood fan will draw air under the ovens and actually blow the pilot flame out. Same fix, increase the flame. You may also experience low gas pressure to the appliance during heavy usage. You would need a manometer gauge to check for proper gas pressure. In short, if the oven goes out during your busiest time when everything gas powered is on, the oven may be starved for gas.
Sep 09, 2010 | Bakers Pride FC-616 Gas Single Oven
Need a wiring schematic for a Bakers Pride p44 double pizza oven.
hi..there is color coding on the wires..BLACK WIRE is the live wire(wire #1) which should be connected on top of the terminal supply of your oven (if vertically positioned) and sometimes to the leftmost right(horizontally positioned),then the RED WIRE to the bottom (vertically positioned),or rightmost part (horizontally positioned) and the WHITE WIRE is at the center(both horizontally/vertically positioned0 and the GREEN wire must be connected to the grounding of the unit just below/beside the terminal supply of your oven..hope this helps
Apr 15, 2010 | Bakers Pride P-44S Oven
Need a thermostat for lang model gpo-1 pizza oven
I'll try to find one for you if you haven't found it already. Please email or call me. 9728590929. Hope this helps.
Aug 21, 2009 | Bakers Pride FC-616 Gas Single Oven
Bottom oven pilot light goes out intermitantly.
adjust the flame so that it stays on the thremal couple and keeps it hot if it is off by 1/4 inch it will not work.
Jul 22, 2009 | Bakers Pride FC-616 Gas Single Oven
Lang gas pizza oven.. Main burners won't lite!
Hello. It sounds like, from what you said, you have a new thermocouple. The device it is attached to, the pilot safety, could have a problem internally that allows gas to the pilot, but does not open the main part of the valve, or electrically has failed on the main coil. If you have a thermostat with wires on it, you can jumper the wires, to bypass it, temporarily please, if it comes on, you need a thermostat, if not, it is the valve most likely.
Hope that helps, and thank you.
Feb 18, 2009 | Bakers Pride FC-616 Gas Single Oven
Pizza oven does not light
thanx for the email reply .oven lighting problem was caused by the pilot light not quite touching the flame tubing
Dec 17, 2008 | Bakers Pride Y-600 Gas Single Oven
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Dec 17, 2008 | Bakers Pride FC-616 Gas Single Oven
Pizza oven bricks need to be changed
You must use a long crowe bar lift the brick and pull it out need the size of the brick to let you know how much and where to get it if it a 2inch thick they are no longer sold most lilkely it 1 1/2 inch
Oct 16, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Door on my bakers pride y600 pizza oven
Theses are called 3/4 door busings and should be changed when you replace the left side door rod (complete)and are available from any parts depot that sells bakers pride parts
Jan 20, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
Ovens Logo
50 people viewed this question
Top Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you an Oven Expert? Answer questions, earn points and help others
