Question about Philips PPF-531 Plain Paper Thermal transfer Fax
Insert card Our PPF-531 fax machine always register an "insert card" notice on its screen. Is there any possible way to disable this notice because we cannot transmit and receive fax when this warning appears. Do we have to buy a card for its card slot or is there a way to disable this "warning" for us to continue using its fax services..? We are really looking forward to your help.
  • 3 more comments
  • agustin Oct 06, 2007
    At last I have discovered a way to disable this "insert card" problem of this fax machine.. It's on the service function of the machine
  • agustin Oct 11, 2007
    LOL! It took me a couple of days to solve this intriguing problem of PPF531. It's funny that I answer my own question. For the benefit of others, the solution to this kind of problem is in the Service Function of the machine. It's function number 97.
  • agustin Feb 16, 2008
    Try this little trick that I have discovered. Press START for 4 seconds, then you will hear 2 beeping sound. Then alternately press START and STOP 4 times. You will see a cursor like display on the right side of the LCD. Press MENU or FUNCTION then input 97. Look for "CARD TEST" then press OK then press STOP. Unplug the device then plug it again. A new icon will appear on the display.
    Pls let me know if this trick worked.
    Try this little trick that I have discovered. Press START for 4 seconds, then you will hear 2 beeping sound. Then alternately press STOP and START 4 times. You will see a cursor like display on the right side of the LCD. Press MENU or FUNCTION then input 97. Look for "CARD TEST" then press OK then press STOP. Unplug the device then plug it again. A new icon will appear on the screen.
  • Anna Hub
    Anna Hub Nov 14, 2018
    It worked for me too, Philips Magic 5 Primo Smart
    Problem Solver:
  • 14 Answers
Guys for thoses of you that have other types of this machine , As i have it,s not the same type as agustin which i want to thank for sending this post as it has help me, But as my philps magic series 5 primo is a different modal i had an old bank card in my wallet or if you have anything with that type of chip on it, then cut the card to the right size and shape to fix your machine (BUT DO IT BIT BY BIT) Till it,s the correct size and shape and just insert it into the machine and close the lid, As i have just done and to my amazment it (WORKED) !!!!!!!!!!!!! and now it,s back to normal and fully working, If you need an image of my card shape and size just email me and ill send you an scanned image of it for you to work with.
Regards Andy8ukuk
email - andy8ukuk@yahoo.co.uk.....
Posted on Nov 21, 2007
  • 4 more comments
  • mai777 May 10, 2011
    funny ! augustin's tip is very useful!
    on a "PHILIPS magic 3 basic" with PFA331 plug'n'print chip card, do this:
    press START 4 sec. until the beep. press MENU then type 94 and scroll to TEST CARD.
    set it to zero. open case. remove the plug-n-print card.
    I now was able ti reuse the spent inkfilm, (scrolled back onto further reel) with no chipcard in place. excellent ! the inkfilm-meter will show NEW INKFILM! very nice hint by augustin. what are the other MENU 97 good for, you think? there are 6 more setting to tamper with but I don't want to screw it up. many Philips faxes have this "secret menu" for hacking !
    sorry, it is MENU 97 . MENU 94 is wrong (typo).
  • mai777 May 11, 2011
    what Andy8 is writing sounds very surprising. probably many fax machines have hidden service menus to disable error messages like those by plug-n-print card unit.
  • ziauddin Dec 18, 2012
    thanks,it worked
  • Sany Dimitrios
    Sany Dimitrios Nov 23, 2018
    Does anyone knows how to exit the test menu?
  • Sany Dimitrios
Tip
Hidden service menu
some faxes, such as Philips primo / magic 3 have hidden service menus.<br /><br />There in menu 97 submenu CARD TEST 1 you can turn off the plug-n-print card such as PFA331. now you can spool back the inkfilm for reuse and sell your unspent chip card at ebay.
on May 11, 2011 | Philips PPF-531 Plain Paper Thermal...
Tip
Disable chipcard check and print forever
to do it, press and hold START 4 sec.
press STOP/START 3x over
enter MENU 97 , scroll (arrow right) to CARD TEST 1
enter 0 (zero) to turn it off.
press OK.
I want to stop my philips magic 5 "replace inkflim from flashing. I'm not able to access my messages or send faxes. I dont have a replacement inkfilm. Thanks
the fax hackers are still researching the method to disable plug-n-print chipcard in magic 5 series. magic 3 series has been solved in hidden service menu.
This means you need to buy a new inkfilm with new chipcard included. sorry.
Apr 04, 2011 | Philips PPF-531 Plain Paper Thermal...
How to remove transmission report after faxing
goto MENU 28 and disable the fax journal ( aka transmission report)
Mar 17, 2011 | Philips PPF-531 Plain Paper Thermal...
My fax machine says "error"
there are some fax machines out in the market which are incompatible and cannot fax to each other. should be maximum 2% of all machines that exhibit those problems. Nothing can be done about it.
Jan 22, 2011 | Philips PPF-531 Plain Paper Thermal...
Disconnect fax
Scroll through the menus and look for "MANUAL MODE"
Sep 23, 2008 | Philips PPF-531 Plain Paper Thermal...
Philips Magic2memo, type PPF 456/10B
Unfortunately the machine will have to be disassembled to remove paper
Jun 15, 2008 | Philips PPF-531 Plain Paper Thermal...
No loop current
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider. But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
Sep 13, 2006 | Philips PPF-531 Plain Paper Thermal...
Philips PPF-531 Plain Paper Thermal transfer Fax Logo
5,495 people viewed this question
Top Philips Office Equipment & Supplies Experts
Damen Wong
Damen Wong
matt martin
matt martin
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
