Question about Krups Bravo Plus 872 Espresso Machine
Water not coming through espresso side although steam wand works fine
When brewing espresso, I get only a small amount of actual espresso. There is plenty of water in the reservoir, and the steam wand works fine - but when I finish steaming the milk and dial back to continue with espresso, no more water is forced through the ground espresso. When I turn the dial back to steam, steam continues. Something seems to be blocking the water on the espresso side. I doubt that the espresso is ground too fine or is packed too hard. Is there a cleaning solution?
  • Anonymous Dec 27, 2008
    I am having the same problem. The wand works fine, but nothing comes through the filter. I have tried running vinegar and water through, but to no avail. I need to fix this. The machine is my sisters!!
  • Sulejman Sulejmani
    Sulejman Sulejmani May 11, 2010
    if you open the steam valve during making espreso. do you get water from steam pipe then??
    Novelist:
  • 137 Answers
You both can have same problem, solution is:
  1. low pressure of pump (or too fone grinded coffee)
  2. security valve of boiler openes to early and dont let the pump to rise pressure enough for good brewing( if it is this you can see water returning back to container if you have 2nd pipe in your machines reservoir)
Posted on Apr 02, 2009
SOURCE:
Water will not come out
Helpful Hints ' Home Espresso Repair
www.espressorepair.com/helpful-hints/
Why isn't water coming through my espresso machine? ... clean, waffle side up, smooth side down, and that the water hose is not crimped. ... After one cup of waterhas flown through the brew head and the steam wand, the vapor lock will be fixed. ...When the ready light comes on again, turn the steam knob open to release ...
No water out of the brew head - Starbucks Barista - iFixit
Dec 28, 2015 | Coffee Makers & Espresso Machines
Steam wand not working
The steam wand ejects steam in order to froth the milk. The steam wand should be cleaned after it is inserted into milk and at the end of each day. Do not allow the steam wands to soak in water overnight since some of the dirty water can be sucked into the boiling tank inside the machine this may cause the steam not to come out
Unplug the machine, take the case off, disconnect the switch wires and test it with a continuity meter. If you don't get any continuity, or if it is constantly closed and never open, the switch is bad.
this could have been prevented by regular maintenance and proper use. The usual suspect is a gummed up wand or brew line or user error. Here’s what to look for and how to avoid it.
First, notice what kind of wand you have. Most semi-automatic and porta-filter espresso units will have wands that resemble those on bottom or right, although the tips may be different. Some tips do not slide up and down to alter the aeration, as the one on the bottom does. If your wand is from an older (1990s) unit, it could have a more bulbous tip and a smaller hole in the tip. wandte1.jpg wandte2.jpgSome of the new wands give you a manual/automatic control.
wandte3.jpg Many of the new super automatics come with an automatic frothing unit, like this one from Jura-Capresso. The nice thing about the frothing wands on Jura-Capresso's new units is that they allow for even more control.
The "Dual Frother Plus" (top) works like the traditional frothing wand. The metal sleeve goes up for steam, down for foam.
The "Froth Xpress Plus" is a very handy device which can be used with the included sleek milk container or a distinct milk container, like a 1/2 gallon jug. The Froth Xpress has a tube (hard for using the included container, flexible for using a different container) that fits into the frothing tube behind the dial shown in the picture above. After selecting froth or steam, the milk is siphoned into a cup below the steam wand. We recommend steaming the milk first, then adding the espresso.
Whatever sort of wand you have, it is essential to keep it clear of solidified milk which can gum up the tip and even the wand shaft. Here are some symptoms of a clogged wand:
  • Little or no steam comes out of the wand
  • Hot water drips from the tip of the wand
  • A squeal or whistle comes out of the wand when the steam function is selected
  • A deep humming is heard when the steam function is selected*
*This is also a symptom of another more serious problem, particularly if you have a pump espresso machine; so if unclogging the wand does not solve it, you should contact a technician.
A good preventative measure against the clogging of a steam wand is regular rinsing in warm, soapy water of the tip and any other removable frothing part. This should be done after each steam wand use. If your machine has a Froth Xpress, it is important to clean all of the hoses, valve, and connectors (be very careful with the plug, however, because it is delicate). All wands should also have steam jetted through them after a frothing cycle is run.
Another preventative measure is to run a steam cycle for about twenty seconds before each new use. This will eject stray particles before they can build up and cause serious damage. There is also a cappuccino cleaner available which can be used in the automatic frothing devices. The solution is placed in a reservoir, and a full cycle is run until the reservoir is emptied. This can be done every few weeks or every few months, depending upon use.
Aside from prevention, there are treatments for a clogged wand. First, remove the tip, if the tip is removable. Usually they are, as in the case of the plastic tips above. The holes are usually big enough to run a pin or even a small paperclip through (emphasize small) to remove the gunk. If these items are too large, do not attempt to use them; instead try using a thin gauge wire from an electrical wire strand. Next, the metal wand itself can have a pipe cleaner run up into it. Start out by putting just about a half inch of the pipe cleaner up the wand, rubbing it around, then pulling it out. Gradually work more of the pipe cleaner up the wand, but never let the length of pipe cleaner in the wand exceed the wand length. We recommend the pipe cleaners with the stiff barbs attached, as opposed to the mostly soft ones. Do the same for all of the hard hoses and connectors. With respect to rubber or soft plastic parts, rinse them in soapy hot water. If flexible hoses form holes, replacements are available (give us a call) or we've even had some luck at aquarium supply stores.
PLEASE NOTE: if you own the Jura X7 or the Froth Xpress Plus, the diameter of the tiny holes is very important. We recommend trying not to put pins into these holes. However, if they must be cleaned and soaking won't work, a smaller gauge wire, a single strand, should do the trick. Always use a strand that is smaller than the diameter of the hole.
Frothing wand technology is advancing at a breakneck speed, but along with these advances come serious precautionary measures for dealing with these very delicate mechanisms. Follow the steps above, and your machine should be producing full-fledged froth for its entire life.
May 26, 2008 | DeLonghi Esclusivo Magnifica ESAM3300...
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
No hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
Nov 28, 2009 | Gaggia Titanium Espresso Machine
Should be brewing but little or no coffee comes
Check the end of the steam wand and the parnello it may be blocked use a paper clip to clear, as for the brew unit the shower screen may be blocked it will have to be removed and cleaned. It is located under the red o-ring, then adjust the grind coarser. If that solves the problem for the coffee, but the steam wand solution does not work then it is clogged higher on the line in the system.
Nov 11, 2009 | Saeco Incanto Sirius Fully Automatic...
Steam comes from wand when set to dispense water.
Check the connection to the boiler from the pump, there is no water going to the boiler. Try this test, remove the brew unit you will see a white plastic valve behind it, carefully lift the small lever on the valve(HOT WATER), if water sprays, then the problen is at the brew unit, if no water then the boiler inlet or outlet is clogged.
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
Water not getting through
If you look under that white nozzle you will notice a small hole that leads to the drain tray, clean out hole and the area or small enclosure around the white nozzle (clogged with coffee grounds), and make sure that if you pour a little water in that enclosure it goes to the drain tray. That will solve the water under machine problem.
For the amount of water from the coffee nozzle, check brew unit, you will have to remove the shower screen and clean, make sure that the unit is not clogged in one of the tubes.
May 19, 2009 | Solis Master 5000 Espresso Machine
Francis francis x5-espresso splatters all over
1) The coffee you are using may not be ground finely enough to provide a proper extraction time, resulting in water rushing through the ground coffee much too quickly. Think of it like water running through a handful of pebbles as opposed to a handful of sand. You want "sandier" coffee.
2) Your gasket (the rubber part that seals the portafilter to the group head) may be worn/damaged and is leaking water when you are brewing. Attempt to contact FF! or Saeco to secure a replacement gasket. When you are not using the machine, don't tighten the portafilter all the way in to the head, either leave it completely disengaged or only loosely attached. This saves wear on the gasket.
3) Your brew water may be too hot. Purge your boiler right before brewing by running water into a bowl without the portafilter locked in. After a few seconds the superheated water will be run out and you're ready to brew.
Mar 13, 2009 | FrancisFrancis! X5 Espresso Machine
The coffee brews fine but the steam wand is not working.
Pressure build ok.
Dec 09, 2007 | FrancisFrancis! X1 Espresso Machine
Krups Bravo Plus 872 Espresso Machine Logo
685 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
