Question about Thomson 28VK25US TV
Thomson Tv 28 DG 21 K
Hi i,ve got a Thomson TV ICC17 series with two problems. 1. Sometimes the tv does not power up the stand by LED just blink 2 then 7 times. 2. If the tv is on the problem is that the picture displayed is larger than normal and the vertical lines are bend towards the inside seems an E-W problem. How can i solve these problems??
  • Celeri Alex Oct 06, 2007
    HI chrispurs1,
    I've followed your advice and i found that Transistor TL 59 was short. I replace it but the problem is still the same. I'm I on the right way??
  • 372 Answers
Hi. This could be the solution for the problem with for the led blinking fault code. The icc17 chassis is notorius for this problem but there are lots of things that can cause it I have listed the most common for you. FAULT DUE TO HT GOING OVER 200V, RP63 243K GONE HIGH IN VALUE, CAN ALSO CAUSE FURTHER DAMAGE, 250V AVALANCHE DIODE RB06 ON CRT BASE AND SOUND OUTPUT IC. CHECK ZL13 FUSE SUPPLY TO FRAME OUTPUT IC. REPLACE TL02 (BF422) AND TL59 (BC857 SMD) IN THE BEAM CURRENT LIMITING CIRCUIT. If your not at all sure get repair shop to take a look try & find one that does free estimates.
Posted on Oct 05, 2007
    Genius:
  • 1,694 Answers
1)Whenever the word "sometimes" is used,a good visual inspection of PS,horiz,regulation & vert. circuits are needed.Solder any/all bad connects. 2)IHVT aka flyback is the usual culprit. Get part # and ask distributor how popular it is? Any info gathered when doing repairwork can be helpful.!
1 dg board, (stv 5v sense time out). ........ive
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
Jun 27, 2011 | Panasonic Televison & Video
Bought in Dubai 3 years ago Pan.Viera LCD 32"\r\nStandby light flashing red/green. Have to switch on with on/off button after a few minutes switches off itself..........then back on itself
Power LED Blinking timing chart
When an abnormality has occurred the unit, the protection circuit operates and reset to the stand by mode. At this time, the defective block can be identified by the number of blinks of the Power LED on the front panel of the unit.
blinking
2 d board
3 d board
4 p board
5 d board
6 su sd sc boards
7 su sd sc boards
8 ss board
9 panel config
10 digi board-
11 pb board
12 h board
13 dg board
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic VIERA TX-32LXD80 32 in. HD-Ready...
Panasonic model th42pz77u no pic, no sound, blinking red light ten times
9.2. Power LED Blinking timing chart
1. Subject
Information of LED Flashing timing chart.
2. Contents
26
TH-42PZ77U:
There are different patterns for blinking light...
10 times indicate DG board problem - SUB 5V SOS, MAIN 3.3V SOS, DTV 9V SOS and Tuner Power SOS.
Aug 16, 2010 | Panasonic TH-42PZ77U TV
Green light continues to blink. TV does not power up for Mitsubihi model WS 55513 TV
Howdy,
Try these ;
1. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067001.
2. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V).
The board is on the left hand side of TV from the back. It is standing up, in a silver box.
Good Luck, BIG IRISH.
Jan 04, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Sony TV Model Number: KV-27FS100L No Power 1. Stand By LED Blinking Three Blinks No PowerIntermittent. 2. Stand By LED Blinking Three Blinks No Power Intermittent. 3. Stand By LED Blinking Two Blinks No...
Try using another power outlet, if you are using a power distribution board then try plugging the TV directly into a wall socket. If using an extension cord then try with another cord. It also maybe that the factory lead that came with the TV is faulty, any of these problems may be restricting the correct amount of amperage required by the TV unit to operate.
Apr 07, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We have thomson tv 32" color crt sort length model 29df45 c s /icc20
tv power goes off when vcd / dish receiver is connected
Aug 12, 2008 | Thomson 29DM400 29" TV
Relay click and 9 blinking led.
Try the following steps:
1. Remove the power supply to X Main board, check VE. If you get normal VE then replace the X Main board. Otherwise to 2.
2. Remove the power supply to Y Main board, check VE. If you get VE then replace the Y Main board, otherwise to 3.
3. Replace the SMPS board & SMPS 200V board.
Good Luck
Mar 22, 2008 | Samsung SPN4235 42 in. Plasma HDTV
THOMSON 28WH101 PROBLEM
Hi
When the TV is in stand by mode, press both volume controls on the TV and the blue botton on remote control for 5-8 seconds. All buttons must be pressed at the same time.
Then the P will disappear.
Good luck
Best regards
sdjejo
Denmark
Oct 31, 2007 | Thomson 21DC320 21" TV
Televison & Video Logo
611 people viewed this question
Top Thomson Televison & Video Experts
 Grubhead
Grubhead
Are you a Thomson Televison and Video Expert? Answer questions, earn points and help others
