Question about Sanyo PLC XU50 Multimedia Projector
Warning lamp glow
Kindly suggest me how to solve the problem my projector xu 50 warning lamp is glowing thanks bedajit
  • 21 Answers
Hi
Does your projector still work?
The warning lamp is there to let you know there is a problem, usually overheating! Make sure it is well ventilated and that the filters have been cleaned.
Try disconnecting the AC power cord and then reconnect it to check if it is still happening.
Posted on Mar 23, 2008
Engine management code po 381 on a nissan qashqai?
if it is a diesel engine the code refers to glow plug warning lamp---circuit malfunction===causes --wiring -- glow plug warning lamp---ECM
check the wiring / check the bulb in the light
Nov 08, 2015 | Nissan Cars & Trucks
Canon lv-x4e lamp reset procedure
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Apr 22, 2014 | Canon LV-X4E Compatible Projector Lamp
Lamp of benQ projector switched off suddenly and failed to light again,but the power button is ON and the fan is working,so what are the causes and how to solve the problem?
Hi
It seems like the lamp has failed. The cause of this is because the lamp can only run a certain amount of Hours before it will fail completely. On some projector models you are able to view the expected fail date and on other there is a warning light on the projector itself indicating that the lamp has reached a certain amount of hours and failure is imminent. Replacing the lamp should solve your problem and is usually quite easy to do
Kind Regards,
Oct 23, 2013 | Sanyo PLC-400 projector lamp Projector...
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Power light orange color Near it a key symbol - orange color Projector lamp not glowing
hi,
If the lamp light is solid orange then, the lamp of your projector is faulty. You have to repalce the lamp.
ok
Aug 01, 2011 | Dell 1409X DLP Projector
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
Lamp does not glow
Sound pretty much like a dead lamp. Problem could be a fan problem or heat sensor or power ballast. We supply lamps internationally so can assist if required as we ship world wide. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Mar 21, 2009 | Sanyo PLC SW15 Multimedia Projector
Sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Jul 09, 2008 | Office Equipment & Supplies
Sony ES4 Projector :
Hi Vinod
I would suggest you to take out the lamp and check for any damage or discolouration to it.
I'm sure that you'll find this to be the problem , in which case you will have to replace the lamp.
May 07, 2008 | Sony VPD MX10 Multimedia Projector
NEC VT 640 projector not getting on
Hi there
Have you changed the lamp yet , or checked the lamp for any marks or discolouration ?
Apr 09, 2008 | Office Equipment & Supplies
Sanyo PLC XU50 Multimedia Projector Logo
263 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
k24674
Rob Hill
Rob Hill
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
