Question about Hunter The Vista 20537 Ceiling Fan
Surged fuse issue?
During a large renovation, i tapped some of the wires together, the light works fine, but the fan seems not to work. I think it is a fuse, the question is where do i get it, and how do i put it in?
  • 625 Answers
The fan motor are lead colors black and white - the light is blue and white. there is no fuse in the unit.
Posted on Oct 07, 2007
Unable to start/ 2000 F250 V10
Try first unplugging battery cable for five minutes, this sometimes fix the problem. If it does not replace electric windows relay and electric windows fuse.
Jul 26, 2008 | 2000 Ford F250 Super Duty Crew Cabs
Chevy s10
With the blower speed set to high and the key on tap the blower motor with the handle end of a large screw driver. If the blower starts to work than replace it.
If it still won't work check for power on the purple wire (i think its purple) and make sure the ground is good. If those two check out fine replace the blower motor.
If there is no power than you will need to check fuses and/or the blower motor resistor.
Jul 26, 2012 | 1997 Chevrolet S-10 Pickup
Wired up this fan - blue and black together to the black wire, white to the white and green to the ground. The black should run the fan, the blue the light. When I turn on the fan without the light...
You really should have an electrician look at it however make sure the lamps are not installed when you are connecting the lamp sockets and also check the voltage across the two leads you are connecting the lights to. Should only be 120 volts. There could be another issue that you are over-looking and that is why I think you should have a licensed pro come and take a look.
May 23, 2017 | Broan-NuTone N-763RLN Combination Light...
Agitor not working, tub not spinning
power may not be getting to the motor or the lid switch may need replaced. If there is a green light flashing on the circut board attached to the motor, it will indicate what is wrong by the number of flashing lights in a sequence. If there is no flashing light or no light at all, the motor may not be getting power or is no longer good. Some washers have an inline fuse in the wires going to the motor that sometimes gets blown during a power surge. It is easy to replace for only a couple $. Feel the wires coming from the motor (unplug the machine and wait several minutes first) there may be heat shrink tubing around where the fuse is at. Carefully cut away the heat shrink exposing the fuse. An ohm meter testing the line on each side of the fuse will let you know if it needs replaced. When I replaced mine I used a scrap piece of wire to jump them together temporarily until I bought a new pico fuse online. just wrap with electrical tape and plug back into a surge protecter until fixed properly. Hope this helps.
Feb 05, 2010 | Estate TAWX700JQ Top Load Washer
Right brake light out; tail light works fine
most rear tail lights and turn/stop lights are the same dual filiment bulb. it is possible for your tail light to work and your brake light not to and still have a bad bulb. I would check the bulb first, your brake light works on the left yes? this would mean that the fuse is fine
Mar 31, 2009 | 2006 Dodge Stratus
Constant power doesn't seem to be working.
you sould have the red and yello wire connected together is you are not using a factory wiring harness adapter this means you might have wires crosses
Dec 05, 2008 | 2003 Subaru Forester
Power surge blowing fuses on amp when car is turned on.
the voltage regulator in the alternator or the capacitor is malfunctioning. get a multimeter on the battery when u start the car (before the capacitor) if it reads a large surge (something greater than 14 or 15 volts) then u may need a new amp, if not, then test it on the back end of capacitor to the chassie negative, see if u detect spike there.
Nov 26, 2008 | Car Audio & Video
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter The Vista 20537 Ceiling Fan Logo
108 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
