Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral Refrigerator makes hollow ice
I have the Admiral 26 cu.ft side x side refrigerator. Two problems: 1. The ice maker is making my ice cubes hollow when it releases from the maker. 2. When we use the ice dispensor, it is SO loud it's terrible. Any ideas to fix this anyone? Thank you.
  • 82MP1SG Oct 05, 2007
    Fridgetech, Great! Thank you. I do have a RO system that is there and runs just as slow. Bet that is the problem.
    82MP1SG
  • Anonymous Mar 30, 2014
    Automatic ice maker in admiral refrigerator leaking water into the bottom of the refrigerator when lever is in down position.
  • 473 Answers
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Posted on Oct 05, 2007
If your filter is over 6 months old, try replacing it first. Its time for a new filter anyway. Thats when I usually know its time for a new filter.
Posted on Dec 30, 2009
My ice is hollow and my freezer looks like an ice cavern.
Check the fill tube where the water comes into the ice maker. Chances are there is a blockage somewhere and little water is getting to the ice maker and the rest is spraying over into the freezer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 05, 2012 | Admiral 26 cu. ft. Side-By-Side...
Is not making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 24, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker not working .making noise but ice not dropnig
heatman101
ys452
Aug 07, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker is not working. it turn and make the turning but no ice is producing.
Hello. Check to see if any water is entering the ice cube mold. Most likely it is not and the cause is either a clogged filter, a clogged supply line, a kink in the 1/4 inch line that feeds the fridge, or a frozen valve that would normally open and close to let water into the ice maker. J.
Ice maker just stop making ice but water still works
LG refrigerator ice maker stops making ice but water stills works
Mar 27, 2010 | Admiral 26 cu. ft. Side-By-Side...
Noisy ice maker
There should be a lever on the ice maker that you flip up to stop it from making ice.
Mar 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Mar 30, 2008 | Admiral 26 cu. ft. Side-By-Side...
Ice make won't drop the ice
The ice mould has a very low wattage element built into it to help release the ice cubes. This heater may be faulty. Most ice-makers have no serviceable parts in them. You may have to replace the complete ice maker.
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
659 people viewed this question
Top Admiral Refrigerators Experts
Jose Pino
steyr1
john h
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
