Question about Hitachi Cine Master PJ-TX200 Multimedia Projector
Light, then Dark
Hi there. I have a PJ-TX200, that now when I watch it goes light (slightly), then darker (slightly)...enough to notice. This happens every 20-30 seconds. It is slight, however others have noticed and it's getting annoying. I've only had my projector for about 1 year, and my lamp just hit 600 hours. Do I have a bulb problem, a light engine problem, or something else? Your advice would be greatly appreciated. I have a authorized service department near by, I'de just like to be able to tell him what I think is wrong. Thanks again. Jon please e-mail to [email protected]
  • 790 Answers
Ok! maybe you have defective capacitors! or lost contact at high voltage section!
Posted on Oct 05, 2007
SOURCE:
Replace inside bulb of projector lamp for Hitachi
check the site below
http://www.aboutprojectors.com/pdf/hitachi-pj-tx200-manual.pdf
thats the manual
Jan 09, 2011 | Hitachi Cine Master PJ-TX200 Multimedia...
Toshiba 32A35 Color TV Flickers & Scrolls w/ light colored images
My Toshiba 27" tv has the exact same problem any solutions out there or is it time to toss the tv?
May 24, 2010 | Toshiba MV19H1 Combo
Slight shadow on part of screen
Hi, There have been several problems lately with the screens doing that. The only way is replacing the screen. I have located the problem causing it, It is the light filters in the panel,not replaceable at this time."pain in *** too"Did it from a broken panel. The light filters diffuse the light evenly so you do not notice the backlights. If you bend it,it will cause shadows like your getting. They heat up and swell a bit. And that is what is causing it. I have contacted Samsung,And Magnavox about the problem. Will not sell replacement light filter at this time tho.The LED backlit will not do this. They run cool.
If I can help you out more contact me at...
[email protected]
Oct 31, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Picture get dark than light
On your remote control, press the huge circle, which should be settings or menu, there, go on brightness, put it up to max if u want bright, and low if u don't .If the problem still happens, ask customer service to help, or return it!!
Feb 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
PJ-TX200 hitachi projector
Hi George86969
Try checking if all the fans are working when you swich on the unit. Normally a static red temp. light is a faulty fan that will have to be replaced.
May 17, 2008 | Hitachi Cine Master PJ-TX200 Multimedia...
Dimension of image change when displaying clear or dark image
Same problem Picked up this monitor about half a year ago, a Viewsonic A91f+, and have been having some issues for a while now concerning what appears to be shifting in the monitor image, but that is about the best I can describe it as. It is most noticable when a large dark area meets a light area, like text or window edges. This "shifting" only occurs on the right side of objects and seems to show most often after I switch resolutions more than a few times, usualy due to gaming. Ive also noticed it happening from running random programs that dont require resolution changing/flickers but this happens FAR less often. -photograph of the effect- As you can see, its pretty subtle on a darker background, but Ive had no luck carturing it on a light one. Anyone have any idea as to what is occuring on this monitor and how it could possibly be fixed? Possibly an issue with magnets? For a while, I did have a small headset hanging off the the monitor on the side that the images "shift" towards, but even taking those off and away havent fixed it. Currently the only fix I have found for this is to shut my monitor off for 5-30 minutes, depending on how bad the "shifting" is when I find a time break long enough to fix it.
Jan 12, 2006 | ViewSonic G790 19" CRT Monitor
Hitachi Cine Master PJ-TX200 Multimedia Projector Logo
132 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
