Question about HP PSC 2410 All-In-One InkJet Printer
Printer makes clicking noise
When I turn on my printer it makes a clicking noise for about 2 minutes and then just stops and the on light is flashing and the hourglass stays on the printer screen. It will not print at all.
    Novelist:
    Scholar:
  • 167 Answers
Make sure the printer is not out if ink. When the light flashes this may be the case. Also check the print queue. If it contains pending print jobs and there is no paper the light will flash. Here is how to check print queue: Click Start > click priters and faxes > double click printer icon and see if there is something ... If you see any print jobs delete them right away. and restart your computer. This should solve your problem.
Posted on Oct 05, 2007
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Ink cartridge changed but computer will not recognize it has ink
Please try the following in an attempt to resolve this issue:
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button.
4. Open the CARTRIDGE COVER. Pinch the front and back tabs of the first cartridge, and remove it from the printer.
5. Place it back into the holder. Push it down gently into the holder, until the cartridge clicks into place.
6. Repeat steps 4-5 for each cartridge. Close the CARTRIDGE COVER once all of the necessary ink cartridges are re-seated.
7. Carefully lower the scanner, until it clicks into place
8. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
CAUTION: Never turn off the printer while the ON light is flashing, unless the printer hasn't moved or made noise for more than 5 minutes.
Aug 30, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Have Ultra Hi-Definition RX595 Photo all-in-one print,copy,scan,photo. After setting everthing up and when I print from word or anyting the print comes out in color. I thought I could have color or b/w...
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
Aug 21, 2008 | Epson Office Equipment & Supplies
Printer
One of the best solution that we can provide you is head cleaning. One of the effective method of Head cleaning is listed below.
1. Make sure the printer is turned on but not printing.
2. Load letter size paper.
3. Click on START. Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) , your printer will require service.
Jun 03, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Black ink
Please try the following to resolved the issue:
Run a series of head cleaning
1. Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
3. Click on START, CONTROL PANEL, PRINTER & FAXES then right click on CX3200 printer Icon then select printing preferences
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 02, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Problem printing
3) Click on START.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 29, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Color printing problem for Epson CX4200
try this :
Please confirm that the head cleanings were done using the most effective method listed below.
3) Click on START.
Dec 29, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Dark red prints with lines throught the picture
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
Dec 20, 2007 | Epson Stylus C63 InkJet Printer
Printing in blue only
try this:
3) Click on START.
Dec 12, 2007 | Epson Stylus CX6000 All-In-One InkJet...
HP PSC 2410 All-In-One InkJet Printer Logo
570 people viewed this question
Clive
Clive
