Question about Linksys WUSB300N Wireless Adapter
Just installed Linuxon my HP desktop. I want to connect to the internet
I have a Linksys WUSB300, dual antenna type, USB connectable, wireless adapter. I'm having a hard time getting this thing to work with my Linux system. It works great with Windows 2000, for a home wireless networking connection to surf the internet. I'd like to do this with Linux though. ndiswrapper doesn't seem to work. What do you suggest I do ?
    Scholar:
  • 132 Answers
Here is a link to a full layout on how to do wireless with Linux and HP. Good luck on your project:
http://www.hpl.hp.com/personal/Jean_Tourrilhes/Linux/
Posted on Dec 24, 2007
SOURCE:
My cisco linksys ae1000 adapter does not have internet connection
If haven't yet check Device Manager, go to Network Adapters and look for Linksys Wireless Adapter. Check the status of the adapt
Also look for errors codes on anything. Make sure all is enabled or need to install drivers.
If all fails remove adaptor and all drivers for it, restart computer and reinstall adaptor.
Aug 04, 2014 | Cisco Linksys AE1000 Wireless-N USB...
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
Usb dowonlod
Hi Sir/Madam;
Here is the source link to download the driver/software for your Linksys -WUSB300 N wireless adapter.
Click here :Linksys
Thank you for using Fixya.
Dec 10, 2010 | Linksys WUSB300N Wireless Adapter
I cannot connnect wirelessly with my linksys e1000 router and was told by their experts that my hp pavilion entertainment pc needed an update for the driver of my wireless adapter. I did go to hp website...
Check the following steps to connect wireless linksys router :
First, you have to connect the router to the ADSL or the cable modem.
Your system has to be set in such a way that it will get its TCP/IP network settings from the router via DHCP.
Second, you need to configure the router to use your Internet service.
Connect the antennas to the Linksys wireless router. Connect an Ethernet cable to the Internet port at the back of the Linksys router and it will establish a connection between your modem and router.
Connect another Ethernet cable between the computer and the router. Then connect the router to an electrical outlet.
Dec 04, 2010 | HP Computers & Internet
Does this PC have a wireless card? If so - where is it? If not - my Linksys card doesn't fit. Can I use a usb type card?
If this has a wireless card it would likely be inside on a removable board. It should have something like an antenna in the rear that is connected to said board.
If there is no card, you can use a USB connected wireless network adapter or you can install a card inside.
Jun 24, 2010 | HP Compaq Presario SR5450F Desktop PC
Hi I have a wireless router linksys wrt100 and I have 2 laptops (notebooks) and a cpu I also have 3 printers (1 wireless and 2 usb cable printers). I would like to make all wireless is is possible. PS. My...
Option1: Install both USB printers on the desktop computer, and then share them. Your laptops will be able to connect to them, but only when the desktop is turned on.
Option2: Buy a wireless print server, (Available from D-Link, LInksys, HP, etc) and use that to connect your USB printers wirelessly.
If you also want to wirelessly connect the desktop to your network, purchase either a USB, or PCI Wireless NIC for it.
Aug 24, 2009 | Computers & Internet
Setup problem
lost my set up disk so would not connect linksys wireless b 2.4 ghz 802.11b usb network adaptor
need to dwnload disk drive for linksys wireless b 2.4 ghz 802.11b usb network adaptor
Sep 08, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Aug 18, 2008 | Linksys WUSB100 Wireless Adapter
Connected to rounter but not internet
Normally this means that you are not putting in the security key or wireless key. Click on the linksys software then go to site survey select your network then click connect and type in the correct security key.
Jul 25, 2008 | Linksys WUSB54GS 802.11G USB Adapter...
Lost internet on my desktop which uses wireless lan card and antenna to connect to linksys wireless g
Just a question, did your girlfriend accidentally kick your computer off the network by accident?
Mar 23, 2008 | Linksys Wireless-G Broadband Router
Linksys WUSB300N Wireless Adapter Logo
147 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
