Question about Panasonic NN-S251 Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
My son was using the microwave, he opened the door to turn the plate inside, when he shut the door and pushed the start button, the timer still counted down and the interior light goes on, but no motor runs. Could this just be a fuse or is it the motor to the microwave? The fan for the range hood still works, just the microwave part is what is not working.
  • 2 more comments
  • rdrobe02 Jun 04, 2008
    Same as Rainylake.
  • Anonymous Mar 12, 2014
    light is on inside my neff built in microwave when the door is closed and the microwave wont switch on the timer is working
  • Anonymous Mar 17, 2014
    My Frigidaire over the range microwave (model no. CFMV156DC F) will not work unless I push the door up and in. The time entered will start counting down though. As far as I can tell the red levers (for lack of better words) that the door connectors go into-the lower one is pushed in farther than the top. As I've not explained very well I've posted a pic. Thanks so much!
  • Anonymous Mar 30, 2014
    Kenmore hood combination 721. Power button doesn't work. Light on with door closed.
    Scholar:
  • 178 Answers
I know that this is an old post but a really common problem. The secondary interlock switch is bad. This problem is caused by only one thing : Opening the door while the unit is in cook mode. This action burns up the contacts in that switch. This bad habit causes about 60% of all microwave oven 'deaths'. The switch sticks closed and the monitor switch blows the monitor fuse, to prevent the possibility of the unit cooking while the door is open. Push the stop button before opening the door and your microwave oven will 'live' three times longer. At least from this condition....
Posted on Sep 20, 2013
  • 473 Answers
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Posted on Oct 05, 2007
SOURCE:
Light nn-sa651s
Panasonic FAQ:
The microwave oven model NNSA651S was manufactured in a way that the oven light turns on only while cooking. - FT
Stupid design!!
Feb 19, 2013 | Panasonic NN-S541 Microwave Oven
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
[email protected]
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Microwave will not shut off when the door is opened. Keeps operating
The door switch has gone bad...
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | Panasonic NN-S933BF Microwave Oven
I have a panasonic nn 2501, .You can set the time, hit start, the time will run , but the microwave does not run. What is up? Door safety switch? Thanks, VIC
you are setting the time on the microwave clock , your press the wrong button ,you can try just putting in the number of mins and press start, or theres cook then time and start. if helpful plz rate..
Jan 19, 2011 | Panasonic NN-S251 Microwave Oven
Our Panasonic NN-S763BF microwave turns on (light goes on, table turns and fan goes on) automatically when we open the door even though the clock is displayed. It works normally when the door is shut....
You have a faulty interlock switch (which the door operates).
This needs to be renewed by a qualified microwave service technician ASAP.
A potential hazard if not fixed immediately!
Oct 06, 2017 | Panasonic NN-S763BF Microwave Oven
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
Microwaved buzzed then fan came on
At that age, a magnetron failure would not surprise me, but I looking at the service manual, the only way the hood fan could be on is if its relay on the control board is on.
I would bet you have a problem on the control board.
I can help with that, but please feel free to contact me directly through our site link via our Fixya link at http://tinyurl.com/yzjozk
Apr 04, 2008 | Panasonic NN-S251 Microwave Oven
MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 05, 2007 | Panasonic NN-S254BF Microwave Oven
Range light and oven vent fan
This usually indicates damage to the circuit board of the control unit assembly. We repair these control units nationwide for only $32.50 postpaid. If you decide first to remove or replace the bulbs or check the sockets or wiring, please unplug the microwave first. Failure to do that is usually how the boards get damaged. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can usually find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383 BUT - I don't recognize NN-2501 as a valid model number. Could you confirm that? Thanks!
Feb 18, 2007 | Panasonic NN-S251 Microwave Oven
Panasonic NN-S251 Microwave Oven Logo
629 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
