Question about Microsoft Windows 98 for PC
Mouse not weracking
I got a gatway solo 3300 and it wont let me use the mouse or the extarnl flopey drive i got the drivers to update it but i cant use the flopey drive
  • 363 Answers
Could this be a problem with the USB on the PC? Check that USB is enabled in BIOS. Give some more info, there may be more things to try.
Posted on Oct 05, 2007
SOURCE:
I have a systemax syx-ms-7309 ser#106603641 i need to know the specs im having issues keyboard or mouse wont work and monitor yurns on says no signal and no picture but the toer has powe to it but th
first the monitor
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your (motherboard to your hard drive) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty
if its a 40 pin flat ribbon type it will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
even something as small as a faulty electrical fan and its lead can cause you problems
computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
if by now you gan get a screen
you might have to uninstall your keyboard restart your computer then reinstall it
make sure the lead connection is secure and dust free (if applicable)
make sure the usb device is inserted correctly into the Ps2 or usb port (if applicable)
click start control panel administration tools computer management device manager scroll to keyboards also mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
this will apply to your mouse
you might have to uninstall the mouse and its drivers then restart your computer then reinstall the mouse and its drivers
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
in windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
hope this helps
Jul 16, 2012 | Systemax Ascent PC Desktop
I tried changing the batteries and using a different usb port, but the light stays on the whole time and neither the pen nor the mouse will work. How can I fix it?
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
as for the mouse
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps don
Mar 13, 2011 | Computers & Internet
My computer does not read neither the flash memory USB key nor mouse.
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
the USB
hope this helps
don
Feb 25, 2011 | Computers & Internet
Cannot download vista driver for Belkin wireless keyboard and optical mouse. I currently only have a cd for XP so wont load on to vista.
Have you tried Belkin's support website? If it's not there it may not officially be supported in Vista.
Have you tried loading the drivers for XP on it? Put the XP cd in the drive, but don't open the cd. Then, go to Device Manager > right click the keyboard or mouse > Update Driver, and then tell it not to search automatically, and tell it to search the cd for the driver, then continue. If it finds a driver it will load it.
Oct 09, 2009 | Belkin (F8E829QBNDL) Keyboard and Mouse
My Logitech Mouse wont work after update
try installing latest drivers for mouse.
Apr 20, 2009 | Computers & Internet
Number lock does not work on gatway
Try updating the driver. If it is a driver problem, this should fix it.
Go to Control Panel > Device Manager > click on keyboard > right click on the keyboard displayed and click "properties" > go to "uninstall driver" click ok. Reboot your computer, the driver will reinstall itself automatically.
Hope that helps.
Jan 08, 2009 | Gateway 7001433 Keyboard
Keyboard type
This problem is very common on laptop computer. What happens is while you type on the keyboard, your hand comes close to or touches the touchpad below the keyboard. The system see that as a mouse click and so your cursor will 'jump' to whatever location on the screen the mouse pointer is at.
This can happen, even if you do not feel your hand touch as the touchpads are sensitive enough to respond to your hand bring just above them.
Gateway and most manufacturers have addressed this common user frustration on new models of laptops by either adding some 'palm detection' to their touchpads and drivers or adding a simple way to turn the touchpad on or off.
Depending what model system you have (solo 9100 vs 9150) and what operating system you are running, you may have a few options.
First off, you must be using Windows 98 to have access to these options in the touchpad driver.
For a solo 9100 you have adjust to touchpad sensitivy. To get to the touchpad settings click Start->Settings->Control Panel. Double click on the MOUSE icon. Click on the TOUCHPAD tab. On this tab you can set the threshold setting as heavy as possible to help decrease the frequency at which the mouse will jump while typing. In the solo 9100 models, this is the only setting that addresses this problem.
For the solo 9150 you can the disable clickin while typing. To get to this setting: Click on START->Setting->Control Panel. Double Click on the MOUSE icon. Click on the TOUCHPAD tab. In the TAPPING section, Place a check mark next to Disable tapping when typing.
If these settings do not help or are not available due to another operating systems etc, then your best option is to physcially cover the touchpad when you are doing things that require a lot of tyings. If you need a lot of mouse/typing, then you can add an external mouse to assist you. I have found that placing a post-it note over the touchpad is more convenient then other barriers since it light sticks to help it stay in place.
Sep 24, 2008 | Gateway Solo 9100/9150 Series Laptop...
My mouse doesnt work?? plz help
Have you tried uninstalling the drivers and reinstalling them.  Update with the new drivers found at
http://www.dynexproducts.com/pc-568-10-dynex-wireless-optical-mouse.aspx
Jul 24, 2008 | Dynex Wireless Optical Mouse
Hpdv9000 laptop mouse wont work
Check if you have installed the latest drivers...
For the touchpad, you should be able to find them on the hp support site
For external mouse, there should be drivers on the manufacturers site or the driver disk that came along with it.
Is it the touchpad that doesn't work, or is it an external mouse?
Mar 26, 2008 | Computers & Internet
Microsoft Windows 98 for PC Logo
21 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
