Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
Vhs won't work
Vhs will play for 6 seconds and then turns off. I've tried cleaning it with a vhs tape cleaner and doesn't do any good.
  • Unspun01 Nov 03, 2007
    I have the same problem. The MWR20V6 plays and records DVD fine, but when a VHS tape is put in, it will only play for 5-6 seconds and then shut off. When the power is turned back on, the tape will eject.
    It also shuts off when recording 5-6 seconds. However, you can play a few seconds, then press pause, then play again for a few more seconds and then pause, and repeat over and over again without the machine shutting off. 5-6 seconds seems to be the magic number.
    It hasn't damaged any tapes yet, but the fact that I cannot use the VHS portion of the machine really sucks. Any solution would be great. The machine looks clean to me. Difficult to troubleshoot when the top is off, since the ambient light from my work area affects the machine (The VHS portion will not even function at all unless the top is on or the room is dark)
  • bjfnaf Nov 15, 2007
    After I turn the unit on it waits about 5-6 seconds and then makes a clicking noise and then turns off. The noise is coming from a gear wheel that is on the left side near the front of the VHS door. If I put a tape in it plays for about 5 seconds and shuts off right after making the clicking noise/vibration.
    Brigadier General:
  • 6,966 Answers
Hi, I recently replied to a similar posting/problem. Pls refer to this link > http://www.fixya.com/support/t210313-jvc_hr_s9700ek Good luck and kind regards.
Posted on Oct 05, 2007
  • Unspun01 Sep 10, 2010
    Thanks for posting. As a follow up to my original problem, I never did find the solution and ended up returning it to the store as defective. Take care.
SOURCE:
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
NO SE VE
If You are not getting a video output from the LG player , get yourself a head cleaning tape ( wet type ) and run it for 15 seconds and then try playing a good tape with out any fungus on the surface.
Mar 10, 2011 | LG MG64 VHS VCR
When I playback what I have recorded via camcorder or through tv it is so snowy you can not watch it through a video player it is perfect
Have you tried cleaning the camcorder heads?
Try putting vhs-c cleaner in your local ebay..... such as (in UK) ....
http://cgi.ebay.co.uk/VIVANCO-VHS-C-Camcorder-Head-Cleaner-Buy-1-Get-1-Free_W0QQitemZ310201454774QQcmdZViewItemQQptZUK_Photography_CamcorderAccess_RL?hash=item48397290b6
Particles from the tape get lodged on the head over time. Its not special to VHS-c - its common to all tape products. Usually a good clean (say 3 - 4 times initially, plus one clean every 20 hours use, or so) prevents the accumulation of residue.
Feb 28, 2010 | JVC GR-SXM58 Camcorder
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Feb 21, 2009 | Symphonic WV806 DVD Player/VCR
VHS Won't play
i had the same problem and it turned out my motor was getting realy weak from exessive use and it would cost me more to fix it then it would be for me to buy a new one
Feb 25, 2008 | Emerson EWV403 VHS VCR
Audio works but no picture
simple clean head with Q tips by hand use the head cleaner on Qtips clean good dont brack the tip on head .good luk
Dec 26, 2007 | Sanyo VWM-950 VHS VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
450 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
