Question about DHD NTX-8496 Car DVD Player
2001 MAZDA MPV WANT START
I HAVE CHANGED THE FUEL PUMP AND FUEL RELAY CHANGED THE SPARK PLUGS. THE VAN WILL CRANK BUT IT WANT START.IT IS A 2001 MAZDA MPV
  • Anonymous Mar 15, 2009
    when i turn my van over it will not start I changed the crank sencor and the pcm.still nothing.
    I can here the fuel pump when i turn my key but nothing comes out of the injectors I also checked for spark and it sparks ones and stops.
  • loca23 May 01, 2009
    i exit the freeway and came to a stop and the engine just shut off by it self , the starter is working and also the alternator it sounds like its going to start but there is no spark ?
Do you actually have spark and fuel? is there power to the fuel pump? have you checked if actual spark is being produced? have you checked the crankshaft position sensor if equipped? it will cause no start condition if its bad also. hopes this help a lil to get you started. i am an ASE certified mechanic but im not ususally on this site so GL.
Posted on Oct 05, 2007
Crank but no start, mazda mpv 2001
Check cylinder compression and post results.
Jul 05, 2015 | Mazda MPV Cars & Trucks
Dodge ram van wont start
Check fuel pump,and fuel pump relay. Alot of newer vehichles have a fail-safe mode that wont let ignition spark, if no fuel pressure is present, or vice versa.
Mar 05, 2014 | Cars & Trucks
2001 Dodge Grand Caravan no spark
no spark conditions could be faulty ASD RELAY OR FAULTY PCM.
Apr 01, 2013 | Cars & Trucks
My mpv wont turn over no spark
If the van was running before you changed the wires, I don't see how it is not firing the plugs now unless you got the wrong wires and they are not making contact with the coil towers and the plugs.
If there is no spark on any of the wires, something happened to the coil pack or the crank/cam sensors. Or a fuse or relay for the coil pack.
I would probably try an old plug wire to make sure, then check the coil for voltage.
Jul 21, 2012 | 2000 Mazda MPV
Mazda mpv cranks but doesn't start
For car no start problem,click the link below :----http://howtobyme.blogspot.com/2011/10/car-wont-start.html
---------Thanks.
Jan 26, 2012 | 1994 Mazda MPV
My 2001 Mazda MPV is stalling and has a rough Idle. While driving the van the vehicle stop runing, After letting the vehicle sit for a while, the vehicle will start. This has happened a couple times over...
Sounds like a Fuel problem? Make sure that fuel line pressure is within specification according specs.
Fuel Line Pressure 0.38-0.42 mpa (55-61 psi)
Fuel hold pressure 0.176 mpa (25.5 psi)
Sep 06, 2011 | 2001 Mazda MPV
My van wont start, it turns over but acts like it is not getting any fuel. Could it be fuel pump or filter?
did you check the spark if occur when cranking engine, if it have spark, direct fuel pump by shorting 30 and 87 pin off fuel pump relay and check if theres fuel go to fuel injectors, check for pressure, if no fuel, connect voltage directly to fuel pump assembly, if fuel turn s, check circuit, if no fuel goes, check the tank for empty fuel, if you have fuel change the fuel pump including fuel filter
Jun 26, 2010 | 1997 Mazda MPV
1998 mpv van strange problem of starting
locate the starter relay and possibly the ignition relay on the fuse panel under the hood or under the dash and replace it.
Robert
Jan 10, 2009 | 1995 Mazda MPV
DHD NTX-8496 Car DVD Player Logo
351 people viewed this question
Top DHD Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Tygh Duval
Tygh Duval
Are you a DHD Car Audio and Video Expert? Answer questions, earn points and help others
