Jensen VM9410 Car DVD Player Logo
K
Kaevin Remoket Posted on Nov 11, 2013
How do i setup the aux in a Jensen VM9410 car dvd player?
The back of the player there are RCA Jacks (red,white,yellow). I have an auxiliary cord thats connected already but when i play a song through my phone, everything works fine except the main singer is either low or distorted. I also have to raise the volume up just to hear the song... any suggestions?
5 Related Answers
chris sasseville
  • Posted on Jan 07, 2006
SOURCE: Jensen VM9410 problem
two things might be wrong is there 12 volts and is there a good ground . hope this might help.
Anonymous
  • Posted on May 28, 2008
SOURCE: Jensen head unit VM9311TS no sound from CD
Should wire HU's Power Const to Amp's Remote On. Instead you wired HU's Power Antenna to Amp's Remote On. So the stock amp got triggered only in radio mode.
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Aug 18, 2009
SOURCE: CD does not eject from my VM 9410 Car DVD Player
it probably got jammed in there what you can do is unplug the power source and replug it back in a brief power push should eject the disk. make sure you have your unlock codes as the unit may think it got stolen if you undo the power. if that does not work to get it fixed around $89 bucks Thanks and please rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • 4 Answers
  • Posted on Oct 13, 2009
SOURCE: Jensen VM9311TS wont play cd
but if the amp isnt powered on, how does it play during the radio? I have the same issue
Anonymous
  • 486 Answers
  • Posted on Dec 06, 2009
SOURCE: how do i get the bypass code for the jensen vm9410
NORMALLY YOU ONLY HAVE TO CONNECT THE EARTH LEAD ( OFTEN PINK) TO THE HAND/PARKING BRAKE TOGROUND THIS TO ALLOW USE DVD ONLY WHEN CAR IS PARKED, WHEN NOT GROUNDED YOU WILL GET A BLUE SCREEN
How do I get my iPhone to connect to my Jensen player?
You will need an Apple A/V cable to plug into the AUX in the rear of your reciever.
Here is the Owners manual for further info
http://audiovox2.info/docs/common/VM9410/VM9410_OM.pdf
3answers
Trying to hook up panasonic veira flat screen tv without a manual. Not sure where to put the red, yellow and white cord.
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors. The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
I cannot understand how to connect my dvd player to my tv
just connect the video(yellow) and audio(red&white) outputs from your dvd using a 3 wire RCA patch cord set to the AUX Video input on the back or side of your T.V.(also yellow red and white) then switch the T.V. to AUX input and play your dvd
II HAVE A 13 INCH BRAND MODEL DWT 1304. I JUST WANT TO USE IT FOR A DVD PLAYER. I HAVE NO REMOTE ,HOW DO I CHANGE THE TV TO PLAY DVD OR VEDIO
Connect the composite video RCA (yellow) cable output of the DVD player to the TV's video input RCA (yellow jack). Connect the red and white RCA cable from the DVD players audio output to the TV's audio input (red and white jacks). Select the source input from the TV's control panel - if it has an input selector switch, set it to select the video source from the front panel input jacks if you connected the three cables - yellow, red and white on the front of the set. Or, change the channel to receive the video auxiliary input source instead of the broadcast station.
How do you hook up this dvd player to the tv. the plugs are blue green and red instead of white yellow and red
The DVD player has component video as well as the S-video and RCA video and two RCA audio outputs.
If your player is the same as my picture, the component video jacks are in a horizontal line at the top of the back of the player. The white and red audio jacks are in a vertical line to the left. The yellow video out jack is in the second line just below the component video jacks (in a line with the coax port, the S-video port is in between the coax and the RCA video out). (The white jack is at the top left of the connections block, red below that, and yellow to the right of the red.)
I hope this helps.
2helpful
Yellow wire unpluged from radio
Sure. The wire u are looking 4 is located in the bottom right side of the plug. Under the Bat (Red) and Ground (Black). On the last hole on the harness. Had same problem. Hope this helps you.
Jensen cd 2610 aux input has little volume
first of all the rca jacks in the back of your radio are for plugging in an amp, not your mp3 player. there should be an auxiliary jack(looks like a headphones jack) in the front of the head unit. if there is no auxiliary jack in the front then you will have to go buy a new head unit with an auxiliary jack.
What cords are needed?
Yeh rca jacks,,the yellow is video and the red and white is audio,,
2helpful
Auxiliary port location?!?! where would it be?
The yellow wires on back one has a white cap the other has a red cap those are the input wires you need to buy the cord that goes from a red and white RCA jack to a 3.5mm headphone jack
Tv tuner for vm9410
YOU CAN CONNECT THE TUNER TO THE AUX. CABLES. AND THEN JUST TURN ON THE TUNER AND SWITCH TO AUX MODE.. GOOD LUCK
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
