Im install driver for scener and I have windows vista and if i install driver write me "This application has failed to start because TwainDSB.dll was not found... What do I have to do?
Be sure the Windows Image Aquisition service is running in the Services Administrative tool.
Comments:
Feb 11, 2008
- The ONLY way I was able to find ANY scanner drivers for ACER products was via their European FTP site: ftp://ftp.work.acer-euro.com/scanner/drivers/ I suggest you try accessing that site and getting the latest drivers they have (which seem to be for their SCSI scanners). They have both an ISO image file and a Nero image file (.nrg) either of which you'll have to burn to a CD to check out.
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable...
(More)
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please give me the solution.
Recently installed Vista and will not scan. Says "No profiles have been created. To create a...
(More)
Recently installed Vista and will not scan. Says "No profiles have been created. To create a new profile use the Mail Icon in the Control Panel"
1.s2w 3300u software did not download what is the problem 2.If it was downloaded then after what is...
(More)
1.s2w 3300u software did not download what is the problem 2.If it was downloaded then after what is the process to use the scanner
