Question about Hoover HTC243 Top Load Washer
Hoover washing machine 200m, making the worst sound ever...
My Hoover 200m is making the worst sounds ever, it only makes this noise during the "Wash cycle" and the "Pre-wash cycle" during the spinging cycles its fine. The noise is hard to explain, but is loud and deep and isnt constant, if that makes any sense at all. Works fine and have still being using it. What could it be and am i able to fix it myself or should i get someone in? Thanks for taking my question
  • Nattyfatty Feb 07, 2009
    Its the exact same sound only in the regular wash cycle and the pre-wash cycle. Ive checked and tightened the agitator and cleaned out the tub but no change. Please help if u can.
  • 209 Answers
Never continue to use a machine that makes any noise it shouldn't you can only make matters worse and could do severe damage that can't be repaired, sound like something in the drum or something loose outside the drum, like suspension etc based on the info given i would just say ask an engineer to have a quick listen, many do a free estimate
Posted on Oct 07, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Loud metal grinding noise during wash cycle kenm ore 11020022011
All Kenmores are the bottom of the line appliances. If under warranty, call Sears. Your machine has problems. May be on it's last legs. None of these sounds are 'normal'. Motors wearing out, likely.
Mar 04, 2018 | Kenmore Washing Machines
Why does washer make grinding metal sounds during wash cycle only?
When it is washing, look to see if the basket is moving at all. The basket should be stationary during the agitation cycle.
Nov 21, 2012 | Kenmore Washing Machines
Washer is making different noises during wash and rinse cycle
could have been the motor,you might also smell like a shellac kind of smell,when the motor overheats,also how old is it and what's the brand name and model number.you can feel the motor,if it's hot then it is cutting out for some reason.
Dec 20, 2017 | Washing Machines
Hoover 200m 4.5kg washing machine will not use cold water to wash. How do I switch it to cold water wash?
You can fix one of two ways.
1/ replace the cold water solenoid valve
This is located directly behind the cold water hose fitting
at the top of the machine
Remove the small electrical control panel by removing the
three small screws.
2/ If you only need the cold wash program you can save
money by swapping the vaves around. They are easy to
remove and they are held in place by a plastic insert which
lifts up to remove them .
Make absolutely sure that your Machine is disconnected from the mains supply before you replace these valves
Regards
Bill K
Tuart Hill
WA
Apr 11, 2010 | Hoover HTC243 Top Load Washer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Not spinning when on Regular wash mode.
sounds like the agitator is damaged and needs to be replaced
Jun 21, 2009 | Washing Machines
HOOVER 510 PREMIER WASHING MACHINE ABOVE THE BELT SHAFT THERE IS A PLASTIC COG WHEN THE WASHING MACHINE IS ON WASH CYCLE IT SPINS FINE ONE WAY THEN ON THE REVERSE SPIN THER IS THIS ORANGE LEVER THAT MAKES...
I imagine you've bought a new machine by now? The plastic gearcog is the clutch housing. The arm that clicks is part of the brake lever. On these models, the brake lever is supposed to hold the clutch in place during the wash cycle so that it slips in both directions to get a forward and reverse wash. On spin, the lever moves away releasing the clutch and gearbox brake and allowing the bowl and agitator to spin together. The brake lever wears and allows the gearbox to slip during the wash cycle. When this happens, the clutch housing will "ratchet" past the brake lever tongue. this causes the "clicking" noise in 1 direction.
Oct 17, 2008 | Hoover Washing Machines
Hoover HTC243 Top Load Washer Logo
380 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
