Question about Kenmore 22422 Top Load Washer
Kenmore top load washer
It will fill up with water but then it does n othing
  • crewri Nov 07, 2007
    My washer will fill but does nothing else. I've tried depressing the slot where the lid switch goes but do not hear a clicking sound. What can I try now?
I just loosenned the two screws holding the switch in and pressed the lever down. It is made of plastic and mine was broken, so I just taped it down and it works. I will have to replace it or bypass it eventually, but for now.....
Posted on Nov 22, 2007
  • 290 Answers
The lid switch can cause this problem. try pushing the lid toward the rear of the machine and see if it starts running. Also check the screws holding the hinge on the left side to make sure they are tight.
Posted on Oct 05, 2007
  • Michael  Lindley
    Michael Lindley Oct 08, 2007
    Just wanted to follow up on your washer problem and see what you found wrong.
    Thanks/Mike
SOURCE:
How to change water line to ice maker.
Turn water off, disconnect the water line, remove old line, install new line, connected the the water line at oth ends and turn the water on. Test for leaks.
Apr 02, 2016 | Refrigerators
I have a frigidaire model FTF530ES1...The orginal shock absorbers became dammed during it's finnal spin. I have replaced the pair, but it's still not spinning....Water does fill, but it will not...
first, check that the drive belt is in place, then open door,put hand inside the inner tub and move up and down to see if has any significant play. if it does your main bearing has fail. buy othe washer. if they are ok. then I suspect the motor controler is bad. part# 134149220 at sears website or service center.
good luck to you. let me know what happens.
Feb 08, 2011 | Frigidaire Washing Machines
I have a 1999 isuzu rodeo and it has a sealed transmission, and it needs to be filled, are there any diagrams or help to fill this?
If your transmission is automatic, you could use a funnel that could fit in the dipstick tube. You could fill an appropriate ammount of fluid in the dipstick via that funnel.
If ur transmission is manual, you have to use a lifter and you could fill it in the transmission inlet by removing the inlet bolt on the side.
Hope that solves your problem!
Dec 08, 2010 | 1999 Isuzu Rodeo
My Quiet Partner III dish washer gets very noisy while filling up with water at beginning of rinse or normal wash cycle. That noise lasts for about 1 minute upon starting only. Would it be a faulty...
yes its a bad inlet valve. sometimes you can turn down the house valve the washer is connected to a little to stop the noise.othe then that replace the inlet valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 27, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Peugeot 406 sri 2.2 hdi estate 2001 'X' plate antipollution fault light on also fuel additive warning fault on, HELP!
im affraid it will be a trip to the dealers the fuel additive tank is located in or next to the fuel tank and can only be refilled by the dealers it also on the othe hand be caused by putting poor quality fuel in (one of our customers used to have the same fault when filling up with diesel from bp) all we did was erase the error code and fill car up at another petrol station, the car has been fine since
Nov 28, 2009 | Peugeot 405 Cars & Trucks
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Washer will not empty its water -hotpoint washer
Chec to see if the water pump is plugged with lint or some othe debris
Oct 14, 2009 | Hotpoint Washing Machines
Water is freezing in the supply line for the ice maker
This usually means you have a weeping water valve. The water valve doesn't completely shut down after filling the icemaker. This deposits a staedy flow of water which freezes and accumulates in the tube, eventually blocking it off. You would need to replace the water valve which is located at the rear of the refrigerstor. One othe thing to check would be the water supply to the refrig. If the water dispenser is working fine then that isn't an issue. However, if that is flowing slowly you would need to replace the saddle valve which is tapping into your house water supply.
Apr 09, 2009 | Kenmore 53502 / 53504 Side by Side...
Coolant light turns on and off on 1995 Volvo 960
You need to fill the system up with coolant I reckon.
Dec 30, 2008 | 1995 Volvo 960
Will not Fill
BELIEVE IT OR NOT, THOSE TWO ITEMS THAT WERE REPLACED SHOULD HAVE RECTIFIED THE PROBLEM.ONE NEEDS TO KNOW IF THE BOARD THAT IT WAS TESTED WAS IN EFFECT A NEW ONE OR NOT. IF IT WAS I WOULD SUGGEST DISCONNECTING ONE HEATER WIRE (IF HEATER IS USED) THEN PULLING THE PR.SWITCH PIPE OFF FROM THE TUB AND SUCKING A VACUME ON THE PIPE. THIS WILL INDICATE A LOW LEVEL CONDITION AND ASK FOR MORE WATER.IF FILLING TIME IS THEN RUNS FOR A LONGER PERIOD, THEN THE PROBLEM IS WITH A DEFECTIVE PR.SWITCH. HOPE I HELPED?
Jun 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore 22422 Top Load Washer Logo
26 people viewed this question
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Gordon Richard...
