Goldstar over range MV1500MG seems to be operating normally, no weired noises, tray turning but no heat, can it be fixed and if so how and is it worth it or should we get new one, thank you
Having noise means some obstruction near the rotating tray or its motor need some lubricant. Has for no cook but control seems working, the magnetron and its fuses is the culprit because it doesn't anymore produce heat to cook food. I hope that advice help you.
If a Goldstar, LG or Zenith MV1610 or MV1608 is running but not seeming to heat a load placed in center of turntable, its probably because the "stirrer" intended to spread microwaves generated by the magnetron around the cook chamber is stuck so that most all the heating is directed toward the back and top rather than the center of the cook chamber.This usually occurs after cooking for longer than a minute with no load in the cook chamber - as when a model w/o a timer (such as a MV1608) is intentionally operated in cook mode to serve as a kitchen timer, or when a model with a timer function (such a MV1610) is accidentally operated for longer than a minute w/o any load.Before assuming the magnetron (usually warranted for 5, 8 or even 10 years) or other high voltage component such as diode or capacitor needs to be replaced, try “cooking” a 16 oz pyrex cup of water at full power on the outer edge of the turntable for 2-3 minutes - which usually reactivates the "stirrer" and restores normal cooking function.
I had the same thing happen to my microwave and the Magnatron was the bad part. There are some things that you can check and I would be glad to help. I bought the parts for around $70.00, but mine was a built in unit.
Let me know, I will help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further. Thank you for your support.
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
