Question about SMC Barricade Turbo Router
Power problem I have my router plugged in but the power light does not go on. Everything else plugged into the plug works. Stopped all of a sudden a couple of days ago.
    Brigadier General:
  • 6,966 Answers
Hi, You would need a VOM (voltmeter) to check that the power adapter of your is giving out the necessary DC voltage to the router from the power plug. If yes and you have ruled out that it is not the power adapter nor the AC mains where it is plugged, try again but do a hard reset. If still a no go, it may be that your router developed a problem in its internal voltage regulation circuitry. Normally inside would be a fuse, a reverse protection diode and a 3 terminal voltage regulator whose output is 5VDC with some capacitors. You should check each that component is ok and proceed to check whatever you can inside the router. If 5VDC can be detected but there are no indicator lights, it may be that the chipset is fried. If this is the case, it may be to your advantage to replace the entire unit rather than do a component level repair. Pls be reminded of safety precautions when working with powered electronic devices. This type of problem is caused by a strong power surge or near lightning strike. If you are not comfortable opening the unit, perhaps you should seek the services of a qualified professional. Hope this be of some idea/help. Post back how things turned up or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
SOURCE:
Its saying my wireless internet is connected but when i plugged the internet cord into the router, it doesnt work anymore! its been like that for about a month & a half now.
Make sure all the wires are connected properly. 1.-Unplug your modem and router from the power supply. Wait 1 minute. 2.-Plug your modem back to the power and wait for all the lights to stop flashing. 3.-Plug your router back to the power and wait for the lights to stop flashing
Follow these steps and your internet should be working again!
Jan 14, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Internet connection stopped suddenly
Switch off power to the modem, router and computer. Now switch on the modem first and let all lights on it to be stable.. Then switch on the router and let all lights on the router become stable. Once the lights on router are all stable, switch on the computer and then try to accerss sites.
May 07, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Linksys Router G WRT54G v5 Stopped WorkingMy router just stopped working yesterday for no reason that I can discern. I had been using it wirelessly for both my MacBook and my iPod Touch. I noticed that the...
What your experiencing is not uncommon. It happened to me several months ago. I had the same router and did everything you've done without any sucess. I then reinstalled the linksys software and that fixed everything.
Apr 03, 2010 | Computers & Internet
Can you tell me if all of the four numbers should be lit up to reflect the Netgear WGR614 is working? My internet connection suddenly quit and I just noticed that on the number "1" is lit.
On a router, the numbers light up only if there is an active computer plugged in to that port. One computer plugged into port 1 the number 1 wil light, and same with 2, 3, 4. No device plugged in to port = no light. Different color lights with different data rates.
Nov 05, 2009 | NetGear WGR614 Router
My Linksys Router has been working fine for 3 years. Suddenly, it stopped working and the Security LED is stuck at Orange and Internet LED doesn't light up. Is it a problem with the Line ?
Router can be misconfigured.
Try to reset to default.
Shutdown your computers.
On the back out the router there is a hole which you can insert a paperclip, toothpick etc, hold it for about 5 seconds then pull out the power plug.
After about 5 seconds plug it back in.
When the lights stabilize boot the computer.
Try to access to default ip: http://192.168.1.1 or http://192.168.1.101
username:admin
password:admin
Oct 20, 2009 | Linksys (NR041) Router
Can't use wireless all of a sudden. Have to plug
You can try first changing the wireless settings of your router like the SSID and channel and check if that will fix the problem, if there's no wireless computer working with this router better reset it by pressing the reset button for 10 seconds while power is ON and after that reconfigure it back..........
Oct 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Belkin N router reads everything but the computer.
If your router was working before, and suddenly stopped working, then you probably need to reset it.
Unplug the router from power, also unplug all network cables from it.
Wait about 30 seconds.
Plug power back in, followed by network cables.
Wait some more seconds while the router restarts.
Only the Power light and the Status light should be solid.
All others in use must be blinking, which means they are in use.
Try connecting to the internet with cable first, then try wireless.
It should work.
Please don't forget to rate if answer is helpful
Jun 22, 2009 | Acer Aspire 5050-3242 Notebook
Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
May 31, 2008 | D-Link DIR-625 (790069292637) Wireless...
Wrt54g V8 Suddenly stopped working
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
May 07, 2008 | Linksys Wireless-G WRT54G Router
Not working ,just red light
If you have all red lights, this indicates a problem with the router. Please contact your ISP to make sure that your internet connection is working correctly. Did you receive this router from your ISP or did you purchase it directly? Has it worked in the past and just suddenly stopped working? Please provide more details for me to provide you with further options.
Oct 29, 2006 | Efficient Networks SpeedStream 5260...
SMC Barricade Turbo Router Logo
188 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
