Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Maytag Performa washer won't drain
By MrOsborne on Oct 05, 2007
Model lat2300aae, fills and agitates, and even drains a little in the rinse and spin cycles, but doesn't drain a meaningful amount. I have a clear hose connected to the machine's drain hose, so I can see a little flowing out. I've checked hoses for clogs, and they flow fine. Replaced the main drive belt because it left my fingers black, even though I didn't think that was it. Didn't do it. I've adjusted the tension on the pump belt so that it's actually a little too taut, just to be sure that's not it.
The issue seems to be in the drain pump, but I don't know exactly what it is. I'm thinking (hoping?) it's clogged, but I don't know if I can open it without breaking it. I'm thinking of replacing it, but I thought I'd ask here before investing the $60.
Any help's appreciated. TIA.
Comments:
Oct 06, 2007
- I pulled off the front panel, and when I removed the hose connecting the drum to the pump, the water poured out. I actually drained the washer that way. I also removed the hose going from the pump out the back and held it upright and ran water through it. Don't ask me how, but I forgot to watch the pump as the spin cycle ran. I kept watching the clear outgoing hose for a flow instead. I'll have to do that tonight.
When I tightened the pump belt, I went beyond the 1/4 inch that the packaging bag suggested, but not beyond the inch that your diagram mentions. I'll release it a little anyway.
Is there a way to open the pump without breaking it, or would I need to replace it?
Thanks again.
Oct 06, 2007
- Now I'm really scratching my head. I removed the hose between the tub and the pump and let a little air in there. I started the spin cycle, and I could see by the foaming bubbles that the pump was spinning fast. I decided that, even though I'd already checked, I'd remove the hose behind the pump and put a garden hose in it. Water flows through it.
For a moment, I ran the spin cycle with the tub and pump connected, and the water flew out the outgoing nozzle of the pump. I reconnected the rear hose and restarted the spin cycle, and again the water only trickled out the back end of the hose.
My next guess is that the pressure of the garden hose pushes water past some obstruction that manages to hold back the lighter pressure of the washer pump. I'm off to buy a hose, and hope that does it.
Oct 07, 2007
- There's a connector between the rear runoff hose and the hose leading to the outbound plumbing that seems to be a sort of venting connector. The problem seems to have been in that. With that removed, the water flows fine. No idea why. I've temporarily replaced it with a straight connection, but I'm guessing it has some useful or necessary function? I've included a jpg of it. Anyone know its function, and necessity?
Thanks again.
Oct 07, 2007
- OK, final outcome. I replaced the air gap with a straight connector temporarily, because I couldn't find an air gap anywhere. It backed up in the outgoing hose, beyond the connector. I removed a pipe in the basement and found a couple of pennies jammed in a pipe. Then the machine worked fine. I decided to try the air gap again, and now it's working fine.
Here's what has me still scratching my head. The problem began when I noticed that the water was only trickling out of the washer. It wasn't backed up in the outgoing hose, it just wasn't flowing. Could the belt have been a secondary problem? Maybe aggravated by the backup? Maybe the backup caused a jam in the air gap that cleared when I rinsed it?
It's working fine now, so I'm not complaining. Just wondering.
Thanks for all the help. Guess I didn't look far & wide enough for the clog.
Same Problem
Apr 15, 2008
-   MAYTAG PERFORMA PAVT244AWW-   Guest
Best Solution
posted on Oct 05, 2007
Very Helpful)
the dr
Rank: Guru
Rating: 90%, 756 votes
there may be a object in one of the hoses going to and from the pump. be sure have you taken the front panel off yet??? If not it has two clips on the bottom on the two sides than the panels swings towards you to unhinge from top. The pump has a clear body and you can visually see an obstruction. Sometimes i find that a metal object coin, etc can actually chew the fins off the impeller. That would be the only reason for it not to pump anymore. Also release the tension on the belt. Maytag wants some slack for the motor to slide on the motor plate proper.
Comments:
Oct 06, 2007
- Yes its a non serviceable pump
Oct 07, 2007
- Yes that is and called an air gap its really a siphon break. If your drain hose goes into a regular style drain standpipe and isnt clamped tight to a drain pipe of some sort it will work just fine. Wow i have had those leak out of the top where the air vent is but ive never had one restrict the water flow. Is there a foreign object jammed inside it??
Was this helpful?
Yes
No
Solution #2
posted on May 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i just took a big shite
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
elite oasis is that a quaitly machine
Answer
What is the most reliable top loader washer to buy?
Answer
when the washer is pumping water in it makes a noise like the pump is starving for water. I have... (More)
Answer
Hello there, our BTWM4 has just stopped working. Gets to the drain and spin but stops. Any ideas?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14866
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
