Question about Pentax ME Super 35mm SLR Camera
Pentax ME slr (old hand film wind )
I bought a used camera from ebay, the second one, the first camera a Minolta works and takes great pictures..the Pentax though a little beatten up works as far as i can tell ,shutter, winding, photo count, etc. but when I had the pictures developed nothing came out!!! I will try it again but like I said every thing seems to work and the batteries are new, and yes, I had the lens cover off. All shots were outside in well lite conditions, film was 400. suggestions or help greatly appreciated. Kenclicker
The film might not have been catching onto the wheel it has happend to me befor
Posted on Dec 20, 2007
Minolta Maxxum 400si is locked up
link to your manual, it tells us that we have a winding motor problem, I would do as you have done, so I would ensure that batterys are in great shape, the only other thing I could suggest is to try to turn the winding motor by hand in case it is just locked up. Failing that I presume the motor has died and needs replacement.
Dec 05, 2007 | Minolta Maxxum 400si 35mm SLR Camera
When i tried to load my Pentax ME super i had trouble winding it through the sprockets and then after not being able to get it, the winder wont click over and the button will not press! any help would be...
I would say the film in the camera is lost.
Take it out with as little damage to the film as possible. If required cut the film and remove from the camera spool.
Try the camera with no film, does it work.
It could just be a bad roll of film, unlikely but possible.
Mar 21, 2010 | Pentax ME Super 35mm SLR Camera
Pentax me super camera, not working wind on lever
The clip spring broke jambing the advance gear. by forcing, the tab on the advance shaft broke.
take or send your camera to a camera repair shop for an estimate cost to repair.
there are no new parts for this model so the repairs could be expensive.
there should be no cost for an estimate.
Dec 10, 2009 | Pentax ME Super 35mm SLR Camera
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Apr 12, 2009 | Pentax PZ-70 QD 35mm SLR Camera
PENTAX mz 50 I WAS TAKING A PICTURE WITHOUIT ROLL
Just a guess, but it sounds like the shutter is stuck in the closed position. Maybe you can have the camera serviced. Try to find an online film enthusiast club, such as on Facebook and elsewhere. They might be able to direct you to where you can have your camera serviced. I can tell you that the cost of that camera is about $100 used, and repair might be the same price, so it might be better to buy another one off eBay. They have MZ-50 models for sale and lots of others. Film gear is cheap these days, but repair is not cheap. Better to buy another camera. I'm sorry about your problem and hope you can resolve it. If this was 10 years ago, you'd have a warranty and could have it fixed, but these days it's just easier to buy another camera and probably the same price or cheaper to buy another used/second-hand camera than to pay for repair. Good luck to you.
Apr 06, 2009 | Pentax MZ-50 35mm SLR Camera
Pentax ME Super Shutter and Rapid Wind Button...
anmolag,
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Film will not advance
Pressing the rewind button wind the film advance lever,if it is free It will set to its place. Release the rewind button, press the shutter release button.Once again try wind the film.( provided your camera is not fitted with motor wind )
Then your winding gears need cleaning
Jan 18, 2008 | Pentax ME Super 35mm SLR Camera
Wind up film button
This is a common problem with the older Pentax SLRs : shutter / mirror box needs servicing . The problem is caused by perished rubber parts. Although the problem is easy to fix, it has to be carried out by a pro because the mirror box has to be removed from the camera so that one can have access to the shutter and the side of the m-box where the problem is. Costs ? +- $150.
Nov 04, 2007 | Pentax ME Super 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
93 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
