Question about Kenmore 74112 Gas Dryer
Won't get hot
I have power getting to the coils, am not sure how the coils work but no power to the igniter.
  • 290 Answers
Check the thermal fuse on the air outlet. If it blows you get no power to the ignitor.
Posted on Oct 05, 2007
  • Michael  Lindley
    Michael Lindley Oct 05, 2007
    The thermal fuse is the one with the 2 blue wires on it.
  • Michael  Lindley
    Michael Lindley Oct 08, 2007
    Just wanted to follow up on your dryer problem and see what you found wrong.
    Thanks/Mike
SOURCE:
Yamaha Fino scooter won`t start after having been used and engine still hot. Have to wait min. 20 minutes restart is possibe. What`s wrong???
Hi, Anonymous you may have a faulty CDI box-pulse coil-exciter coil or ignition coil for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
ZUMAFORUMS NET View topic Scooter won start when hot
scooter wont start when hot
http://www.49ccscoot.com/manuals/Yamaha_Vino_125_Service_Manual.pdf
OEM parts for Yamaha
http://www.yamaha-motor.com/assets/service/manuals/2008/vino125_lit-11626-21-54_1538.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Oct 02, 2014 | Yamaha Motorcycles
No hot wire going into coil
that wouldn't make it work properly,I would check the ignition control module, the power goes to it first, then to your coil, if your getting power to the control module and not to the coil then the module is the problem. If you just put a hot line to it you can lose more parts then you think.
I’m happy to assist further over the phone at https://www.6ya.com/expert/brock_d67526d2a834c47e
Dec 09, 2013 | 1992 Dodge Dakota
1994 jeep laredo stalls when hot. Won't start till
by pass the starter motor see the diagrams attached, and chart for troubleshooting. God bless you
159fe92a-9a7e-4f86-bf05-dd0c28d0ca5b.gif7a5969b1-4b92-441e-8cbf-df7c579bfc60.jpg260df33a-d478-404a-8d61-b6596b1a7499.gif
Sep 30, 2013 | Cars & Trucks
Troy Bilt GTX 18 lawn mower engine won't continue running
ck. to make sure the wire to the ignition coil is hot. may need to replace the ignition switch.
May 24, 2013 | Garden
I lost the keys to my 2005 ninja 250 and had to replace the ignition but i had to hot wire it to get it home I have since replaced the ignition and now it won't start I'm getting power to the
Check down by the battery and the fuse box area and make sure that all the fuses are good. It may have blown a fuse when you where hot wiring it.
Dec 15, 2012 | 2005 kawasaki Ninja 250 R
1988 jeep won't start
Not sure if I read your post right, but you have to have a hot wire to the ignition switch from the battery, independent of anything else on the car, before the switch will work.
The CPS is a common problem on the jeeps, though. If bad, you may not get a coil signal.
Jun 10, 2012 | 1988 Jeep Cherokee
I have a 1985 dodge ram with a rebuilt 360 it starts and runs good for about 20 or so minutes and then looses power and dies and won't start back till it sits for 10 or 15 mins, I have no clue what is...
After it dies, check the spark and make sure it is able to jump at least a 1/4 or better gap and has "snap" to it, not orange and "fluffy". Also if no spark, check the ignition box on the fender. Both coil and ign box can misbehave if they have an internal problem after they get hot. If you have a lean burn computer on the air cleaner tap on it lightly with a wrench etc. (sounds crude but it works) If the engine stutters or changes how it idles, the computer is bad. (one that old can be converted to older ignition system but check emissions regulations before doing that.
If ignition system is working, make sure that the carb is not flooding and that fuel pressure is around 5-7psi.at the carb inlet.
Oct 12, 2011 | 1985 Dodge Pickup 4WD
My 98 ultra classic won't start how do check if my coil is getting power i already pulled a spark plug wire and checked for spark there is none so i'd like to see if the coil is receving power from...
The coil has two primary connections. One side is the "hot" side and one is the ground side. Take all the wires off both ends and position them so they are not touching anything. Turn the ignition switch on and check the wires for one with battery voltage on it. That wire will be on one post of the primary side of the coil and may have other wires that don't go "hot" when you turn the switch on. That's the wires going to the ignition control box. It gets it's power from the same point that the coil gets it's power.
Good Luck
Steve
Jul 17, 2011 | 2000 Harley Davidson FLHTCUI Electra Glide...
1991 Toyota Celica, after running at temp. won't restart until it cools down. I don't thing the radiator fan is running. Also, it won't even crank, all the dash lights come up like usual but...
Usually that happens when the ignition coil gets hot. Not sure if your car has one. It looks like a round cylinder with a spark plug wire connected to it.
Nov 17, 2017 | Toyota Celica Cars & Trucks
Kenmore 74112 Gas Dryer Logo
89 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
