I have a sony memory stick pro duo magic gate mark2 4gb. used in my sony camera. my memory was full and so took our this memory card and replaced it with new one. now this old memory card is not working. it is unreadable in my camera and pc too. i tried to read it with enter1111 usb 2.0 memory card reader but it is not readable. i want to recover my lost pics on that card . please help me
Recovering memory stick data can be tough, you can try recuva (http://www.piriform.com/recuva). This is a very good tool for recovering data, it includes a quick scan and a deep scan.
If the recovery works or you decide the data doesn't matter or you wish to use the card again, then to format it (this will delete EVERYTHING on the card) for normal use then the HP USB disk storage format tool is the best for this, I know it says USB, but it works for cards too: http://en.kioskea.net/download/download-127-hp-usb-disk-storage-format-tool
Be careful when using this tool, ensure you have the correct drive letter selected.
SOURCE: memory stick pro duo sony won't read
Files on a flash drive and memory cards in a card reader can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the memory card and flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
SOURCE: sony memory stick PRO duo 4gb card says memory full when empty
Do you have an adapter that you can use to plug it into your computer? If you do ... try formatting and defragging the chip with your windows tools.
SOURCE: my laptop cannot read memory stick pro duo 2gb
same problem here The driver is recognized but not opened
SOURCE: Sony 1GB Memory Stick PRO Duo Memory Card not
check it with other computer may be problem with OS . So check it
SOURCE: My Sony memory stick pro
Some Sony Cybershot camera's have a small amount of memory built into the camera. Double check that the camera is set to put the pictures onto the memory stick.
If the camera is set up correctly, the memory stick may not be formatted correctly for your computer. If at all possible, connect the camera to your computer directly with the USB cable that should have come with it.
