Back to:
Quicksilver , Mac ATI RADEON 7000 64MB DVI/VGA Video Card  -Limited Supply Graphic Card
Appending text doesn't work
posted by mandybliss on Oct 05, 2007
When I summon quicksilver to append text to a document everything seems to go fine but later if I open the document, no new text is present.
I can enter text after hitting "command .", I can tab over to select "append", and find the document. When I select the document, quiclsilver seems to respond but then when I open the document it hasn't changed. Is there a setting I need to adjust to make this function work?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Graphics Cards problems?
Graphics Cards
I think my graphics card isnt working as good as it should...
Graphics Cards
windows vista ultimate, nec model nec versa S32001
Graphics Cards
Hello, Within Premiere Pro CS3 the footage (SD AND HD) is...
Graphics Cards
I lost disk driver car
Loading problems.
Repair Service
Find Graphics Card Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
