Question about Microwave Ovens
F-9 My microwave stopped heating. It turns on for a while and then stops with an error message F-9.
  • cherialice Oct 05, 2007
    The model is 721.62362200
  • blashwood Mar 30, 2008
    F-9 (tsskk, tsskk for 11 seconds then dead stop). Found the tech sheet that states exactly what is posted here (inverter failure). Where exactly can we find the part(s) needed? We can do it ourselves.
    Problem Solver:
Do you have a diagram for me to fix my kenmore microwave it displays a F9 error code after seven seconds just need the repair manual for me to fix it thanks. jzelaya@cox.net
Posted on Jan 19, 2008
  • 473 Answers
Need to know the entire model # on the microwave.
Posted on Oct 05, 2007
  • 1 more comment
  • Craig Shelton
    Craig Shelton Oct 06, 2007
    Will get back to you asap.
  • Craig Shelton
    Craig Shelton Oct 08, 2007
    f-9 means inverter failure.
    1. Unplug the oven for at least 40 sec.
    Check to see it this solves the problem.
    2. Check the resistance of the thermostat.
    It should be close to 0 ohm.
    3. Check wiring to the inverter and control
    system.
    4. Replace Inverter Module.
    5. If problem persists, replace control system
    assembly.
  • Linda Lechlider Ellis
    Linda Lechlider Ellis Apr 07, 2014
    modle # 721.63763
Microwave won't stop running
there's a ghost in your microwave, call ghost buster. Seriously, the problem is the control panel. (((((the microwave oven can store thousands of volts of electricity in its high voltage capacitor, even after the microwave oven has been unplugged. That's more than 30 wall outlets combined.
Replacing electronic parts in a microwave oven can be extremely dangerous.))))))) tank you
Samsung Model SMH1816S XAC Parts
Mar 30, 2014 | Samsung Microwave Ovens
The turn table stopped turning and the unit stopped heating.
the turn table stopped and the unit stopped heating.What should I do?
May 30, 2011 | Goldstar MV-1501 Microwave Oven
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
Nov 14, 2017 | Magic Chef CMV1000B Microwave Oven
Microwave stop working
my microwave oven just stopped heating giving me a f9 error .lights are on clock is working and the panel is ok.
Jun 15, 2010 | GE Profile Spacemaker Over-the-Range...
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
Microwave, adora, stopped heating
Hi and welcome to FixYa,
Almost always, on most microwave including GE Adora, no heat with all else working indicates a problem with the magnetron. Since the magnetron produces high RF energy and operates on high voltage, it would be to your advantage to seek the services of a qualified professional.
If on the other hand, the fault of no heat is coupled with no display, error messages, door not locking, no light, then it would be possible for a DIY (do-it-yourself) repair. All that is required is a bit of familiarity with electronic components and circuitry, the use of a DVM/VOM of course safe working practices when repairing electrically powered devices.
Pls post back any other symptoms or indicators other than 'no heat'.
Good luck and thank you for using FixYa.
Mar 14, 2009 | GE Adora DVM1850 Microwave Oven
F-9 error on LG microwave
This is a problem with the inverter or magnetron. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. You can find support for service or parts at http://us.lge.com/support/support.jsp
Sep 15, 2007 | LG LMVM1945 Microwave Oven
Microwave Ovens Logo
368 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
