Question about Roper REX3614KW Electric Dryer
Dryer not working
Just moved changed the power cord from 4 prong to 3 prong connected the dryer, and now its not heating up....What can I do
  • Oldjoe Jan 01, 2008
    need color code wire/ to attch 3 pole 4 wire to Roper dryer. that is missing paper work & cord
  • Anonymous Mar 15, 2014
    i changed the cord from 3 prong to 4 prong and the dryer is not working
Roper dryer RES 7745PQ0 wont start. It appears that no power is going to dryer. Nothing works. I have checked fuse. Nothing. Please help.
Posted on Dec 23, 2007
  • 290 Answers
Assuming the problem is associated with you changing the cord, it sounds like you have a wire crossed on the power cord. Double check how you have the cord installed first. If that is correct check your power to the dryer. Since you changed the type of cord, I assume you have had outlet replaced or have just moved to new house. If you have a fuse box instead of a breaker box, check your fuses. It takes two fuses for the dryer. If one of them blows, the motor will run but you wont get heat. The motor runs on 120 but it needs 240 for the element. I can't count how many people have bought a new dryer just to find out they only had a house fuse blown and nothing was wrong with their old dryer. If you have had wall outlet changed there could be a wire crossed in it.
Posted on Oct 05, 2007
  • Michael  Lindley
    Michael Lindley Oct 08, 2007
    Just wanted to follow up on your dryer problem and see what you found wrong.
    Thanks/Mike
My dryer's power cord has 4 prongs, my wall socket has 3 holes, can I change the power cord, or is there an adapter to change from 4 to 3 pronges.
Un screw the 2 hex screws from the back of the dryer where the cord goes in.
There will be 3 screws that connect the cord to the dryer, loosen or remove them to remove the 4 prong cord.
A hardware store will carry the 3 prong cord you need, tell them it is for a dryer.
Re-connect the 3 prong cord to the dryer.
Plug in and test after you have installed the new cord.
Jan 02, 2011 | Asko T701 Electric Dryer
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 | Dryers
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
I was switching the electrical cord from a 3 prong to a 4 prong and grounded a hot wire. there was a big pop and now i cant get it to start. would i have blown it up?
WHy are you switching the cord from a 3 to a 4? If the dryer came with a 3 prong cord and its a 3 prong terminal block, then i dont think you can change it to a 4 becuase you will short circuit. DOes the terminal block where your cord was hooked up have 4 terminals. Each termial can only have one lead/wire to it. check your circiut breaker panel? Is the circiut breaker tripped?
Jul 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How do you install a 3 prong power supply cord to a GE Dryer?
DO NOT CHANGE THE POWER SUPPLY CORD.
you can't change the power supply cord.
the cord came with the dryer is 240v. the three prong is 120v. the dryer will burn up. if you change the power cord without changing the regulator , motor, and the heating element.
you need to get a electrician to run a 240v double breaker from the panel to the dryer.
Apr 23, 2009 | GE DVLR223 Dryers
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
Dec 27, 2008 | Frigidaire GLEQ642A Electric Dryer
II HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 17, 2008 | Whirlpool Dryers
Roper REX3614KW Electric Dryer Logo
255 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
