Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Color in picture only good in 4 corners
The picture tube on my T.V. has been getting 'waves' of color flashing across it periodically for the last few months. Over the last couple of days we have noticed that there seems to be a large cross pattern of bad color for the bulk of the T.V. screen, and the color only seems good for about 3" rectangular sections on all of the corners. This phenomenon is perfectly symetrical. Any ideas would be greatly appreciated!
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
I think it is a magenatic effect called degaussing problem. please remove anything very near to it which has got magnet like speaker headphone etc. call tech to gegauss it. it is hardly 5 minutes job. please do not change the angle while watching tv. your tv seems to be 100% ok. good luck.
Posted on Oct 05, 2007
SOURCE:
Sony Trinitron model # KV-27HFR- the picture is fading, is there a way i can fix that?
From your descrition the problem is the picture tube, over a period of time the guns build up crud reducing the emission on the front screen which in turn causes fading and progressively gets worse until viewing becomes impossible. One possible solution is to have the picture tube rejuvinated by a tv tech to buy more time out of the set, but the improvement may last a few days to several months or more.
Sep 18, 2011 | Sony Televison & Video
For the last couple of months there's a buzzing sound when the TV is powering up. A couple of times I list picture during a show but, I powered down and the picture came back. Now, I don't even get a...
You could have 2 things Color Wheel and Lamp needs to be replaced Color wheel is what Making buzzing sound,
Go to Encompass Parts Distribution 1-800-638-3328
Type in your Model # they will have list of Parts/Supplies
Oct 05, 2010 | Samsung HL-R6167W 61" HDTV
I own a KP-57HW40 set that has a color and shut off issue. Started as a green tinge problem to the screen after watching for a few hours. Started becoming more and more frequent a couple months ago....
IF YOU HAVE A RA 6 CHASSI THE TUBES RUN HOT ANOID CATHOD SHORT IF YOU TAP ON THE NECK OF THE TUBES AND GOES TO SOLID COLOR THEN SHUTS OFF YOU HAVE TO REPLACE THAT TUBE ALL 3 TUBES WILL HAVE THIS PROBLEM
Feb 09, 2010 | Sony KP-57HW40 57" Rear Projection...
Hitachi 53sbx59b horizontal wave lines
I would check the main power supply for a bad filter cap. That could cause the wavy lines. The different colors are probably a problem with the convergence circuit. Try resoldering the convergence ICs first. If that does not resolve it replace the ICs. Also check for low valued resistors in that same circuit or pico fuses.
Dan
Sep 13, 2008 | Televison & Video
Red picture
Assuming this is a TV with a picture tube and not plasma or LCD; I'm afraid that your picture tube is dying on you one electron gun at a time. From what you said your green electron gun is almost totally dead and the two remaining blue & green guns aren't far behind. Eventually you'll have no picture at all and I would estimate that to be about 6 more months but whatever the time eventually it will go totally black. These blackout periods will get longer and longer. The only way to fix your problem is a new picture tube but my will probably find it less expensive to just get a brand new TV set.
Apr 14, 2008 | Toshiba 36A50 36" TV
Sony KV-32LS60U FD Trinitron 32
Your tv has Leak cap in POWER supply its either primary or secondary power. Need to replace it. Look for a Electronic Tech.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
KV35S42
Classic bad picture tube! End of natural life for that make/Model.
The  current sensing circuit is turning the video on/off.
The orangey look also indicates CRT no good.......T.
Oct 20, 2007 | Televison & Video
Picture Flashes off and on
probably the tv has a loose solder in the board. this is normal especially when tv is aging. most of the components inside are emitting heat resulting to loose the solder. try to inspect and resolder if possible. but if you dont have the proper tools and equipment and you're not inclined with this kind of job, better bring it to a qualified tv technician. good luck!
Jan 31, 2007 | Sony KV-32S45 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
