Question about AOpen MX46-533V (91.89U10.061) Motherboard
Long beep im getting a long beep when i power my computer...it was doing it yesterday and it went away then it came back today...dont know what to do...please help...
Ram problem
or ram slots check it
Posted on Feb 07, 2008
Testimonial: "thanks"
  • 883 Answers
It's possible that one key on the keyboard may stuck be in the pressed position, but somehow releases itself. try another keyboard or disassemble and clean this one.
Posted on Oct 05, 2007
SOURCE:
Computer beepping
If you know a clock spring is bad why are you here?
Jan 30, 2013 | 2001 Lincoln LS
Im not getting any power to the coil i was yesterday but not today i dont know whats going on.
check the crank sensor wiring harness. pull on the wires a bit, to see if it will crank over. it should be against the firewall in back of engine. its a 3 wire connector. they are prone to fail.if wire harness is bad, replace it. hope this helps!!
May 26, 2011 | 1991 Volvo 940
Ok, im a newly owner of a 1981 Fiat spider 2000. I know nothing about them other than i really like them. I went to pick it up yesterday and it would not start unless i used starter fluid. I went back...
There is also the fuel pressure regulator, that regulates the fuel pressure. So it might not be the fuel pump. And there is also the fuel pump relay switch that may be faulty. So if i was u, id check there also. Hope this helps u :)
Jul 14, 2010 | 2006 Fiat 124
I own an HP Pavilion tx2110us, yesterday the laptop was working fine, i sent it to sleep and went to bed, today at the office, the computer simply doesn't start up, it powers up for about less than 1...
Remove AC power and then the battery. Then just plug in the battery itself (no AC). See if the laptop will power up. If it does plug AC power back in and don't use the sleep mode as there are problems with some Microsoft updates stopping the computers from resuming from sleep.
Please let me know how you get on.
Good luck.
Feb 22, 2010 | HP Pavilion TX2110US PC Notebook
Advent 8315 Screen blank when powered up
did you check to see if that was the correct serial number of the laptop that you got back from the repair center
Aug 21, 2009 | Computers & Internet
Beeping noise and will not start back up
Hi there.
Open the side panel on the computer case (make sure its turned off and the power cord is removed from the back) take out the system memory (ram), get a clean dry paintbrush and clean the brass contacts on the memory and also clean any dust away from the slots it goes into, once you are happy that all the dust has gone reseat the memory making sure its well seated and clipped into place, close the side panel, return the power cord and turn on the PC, hopefully this will sort the problem out.
Please post back with the results.
Good luck and thanks for using FixYa!!
May 14, 2009 | Dell Computers & Internet
Asus A7V8X MX SE loooong beeps
It is either a memory issue or the power supply issue....
Try to reset memory modules.....If the machine still beeps after this and there is different memory modules installed try to remove each and boot(switch on).....to verify if any memory module is faulty.....if this doesnt work try replacing the memory.
If the problem persists try to verify if the power supply is ok.....
Nov 08, 2008 | ASUS A7S8X-MX Motherboard
PC will not reboot.
Either something has wiped out your operating system and you need to reformat the hard drive and reinstall it, or your hard drive went Since it worked fine the day before and just did this right away, my guess it that your hard drive went bad. But you can try both options though. Hope this helps.
Sep 13, 2008 | IBM ThinkPad T30 2366 Notebook
Monitor wont turn on, just green flashing light.
double check that all yor connections are tight. Open your PC case (unplug it) and ensure that all your fans are clean. It appears that your problem is due to loose cable connections, but this may be a good time to do some computer spring cleaning.
Apr 29, 2008 | Acer AL1916B 19" LCD Monitor
Samsung g600 - receiving a call
Click Menu > # Settings
1 Phone settings
On this you can change the setting on what to be displayed when you receive a call.
Phone settings
→ Show caller
information
Set the phone to display or
block caller information on
all missed calls and
incoming messages
Let me know if you need more info
Jan 01, 2008 | Nokia 1600 Cellular Phone
AOpen MX46-533V (91.89U10.061) Motherboard Logo
67 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
