Question about Vizio P2 42 in. HD-Ready Plasma Television
Tv channel problem
My 42" LCD HDTV by Vizio doesn't change channels by the remote, or the buttons on the TV. This was an auction product, which was originally a return, but channel 10 works fine. The volume buttons work. On the menue, it states "no channels" When I push info on the remote it says "not rated, cc-off". Is this a programming problem. I don't have a manual with this set... Bob help!!!
  • Anonymous Mar 16, 2014
    i havent got a manual anyway i thought i put the radio on my tv now i dont no what buttons to touch to get my telly channels back on
  • 363 Answers
- I think you mean model P42. You can get the user manuals here:- http://www.vizio.com/support/downloads/ Note that the quickstart guide file is broken. You have to allow pop-ups, select the model and the manual will appear in a new window then you can save/print. Hope this helps! -
Posted on Oct 05, 2007
  • 790 Answers
Set your TV! go to menu then click auto search!
  • Anonymous Oct 05, 2007
    then your unit is searching the channels available..
SOURCE:
VIZIO E470VA LCD HDTV Dish Hopper remote doesn't change volume
Try another remote code, many of the Dish or Cable TV remotes will have multiple codes for a particular brand of TV's
Sep 01, 2012 | Vizio E470VA 47 in. HD-Ready LCD TV
My 42" Vizio TV turns on and says No Signal, then
push INPUT on remote, select the input source you want, keep changing channel to find a exist channel.
Mar 25, 2011 | Vizio 42 in. LCD TV
Vizio TV remote is in conflict with Shaw TV remote. When the TV is on, the Shaw bow and the shaw remote control would not work. I turn both systems off, then turn the box on with the remote, select a...
You need to "program" your Shaw remote to control your TV, including the volume up/down on the remote.
Take your Shaw remote control, and follow the instructions on the back. If that does not work, telephone Shaw, and ask for technical support for TV.
Mar 09, 2011 | Vizio M420VT 42 in. LCD HDTV
Our tv turns off when turning the channel by remote and on the tv
Have you tried to unplug everything from your TV for a minute or so and changing the batteries in your remote? I had that problem once. After you do that, try to turn on the tv only with the remote and change the channel. If you are using more than one remote (i.e. a comcast cable remote and a tv remote at the same time the signals cross).
Dec 03, 2010 | Vizio VW42LF 42 in. LCD HDTV
Vizio 42 inch remote is dead. Except volume up /
No,ur main reomte CPU is dead,this problem happen to many remotes in many tv models.Buy a new remote in this website 1-800-Remotes Factory Original.Get the same exact remote.
Jan 13, 2010 | Vizio VW32L 32 in. LCD HDTV
Channel button on tv and remote control dosent work
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Mar 07, 2009 | Vizio GV42L 42 in. LCD Television
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Tv not changing channels.
This likely has a bad main board.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Oct 05, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P2 42 in. HD-Ready Plasma Television Logo
370 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
